Old 09-20-2018, 07:19 AM   #1
72timemachine
Did GM use the same spindles for both vans and trucks?
For example, if you had a 1972 g/10 van with front disc and a 1972 c/10 also with front brakes, would the spindles be the same? I understand other parts on the suspension may be different.
Thanks for any help.
72timemachine is offline   Reply With Quote
Old 09-20-2018, 12:33 PM   #2
clay68c10
clay68c10's Avatar
Re: Did GM use the same spindles for both vans and trucks?
Knowing how GM does things, I’d suspect they are the same.
Maybe someone with a Hollander manual will check in.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
