L83 swap 72 C10
Would like to hear from anyone doing this swap. Bought 2018 L83 with 6speed auto with 2 miles on it for under $5K. Now the money starts going out!!!
Its a Truck Thing......
Re: L83 swap 72 C10
So far,
Pain in the rear..... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
Re: L83 swap 72 C10
Any updates. Just bought my 2018 l83 6 speed auto. Going into 68
Re: L83 swap 72 C10
Seen a few of these combo's up for sale with low miles for less than 5k as well but wonder about the aftermarket for swaps. Just read the L83 has a provision for engine driven HPFP for its direct injection system. That is something eh! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Re: L83 swap 72 C10
Got mine for a killer deal. Couldn’t pass it up. One question was, for vacuum did guys just tap the back of the manifold for their brakes and if so did it affect the systems ecm. Please let me what what y’all did for brake booster vacuum. Not trying to go with the hydra assist
Re: L83 swap 72 C10
Just got my wiring harness back. Will start in April putting the engine and trans in.
Re: L83 swap 72 C10
I'm doing this swap also. In regards to the vacuum for brakes, I've seen it done with a tap in the back of the manifold as well as using the belt driven vacuum pump on the engine, both will work. There are a couple threads in the engine and drivetrain LSX swaps section, lots of good info there. Where did you get your harness done Howell57?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
Re: L83 swap 72 C10
I too was told about tapping to the rear of the manifold. I just read that it may interfere with the sensors or it messing with the performance of the engine. Sorry guys, I’m very new to this. I would consider doing the lt1 swap just to get the vacuum but would rather completely as stock as possible. I’m going to delete the dod so the vacuum pump will go. My luck it won’t fit so I’m planning for it not fitting lol
Re: L83 swap 72 C10
Mitch Vannatta swaptimeusa@gmail.com He is also on YouTube under Swaptime. That's all he does now is harnesses and he is good.
Re: L83 swap 72 C10
Thats cool. I think I recommended him to you if my memory serves me correctly.
Re: L83 swap 72 C10
I’m also using Mitch. Really nice and knowledgeable guy
Re: L83 swap 72 C10
Cornerstone have you dropped ur engine in? If so how did it go and what motor mounts did u use? I’m planning to keep it as simple as possible. I want to use vintage air, I cupped my lca’s and have cpp uppers, rear c-Notch, stock power steering.
Re: L83 swap 72 C10
Yes I have it in the chassis now. The body is off so there was zero difficulty. I started off with some adjustable adapter plates from ICT billet and SBC motor mounts. I didn’t like the setup, it’s been a while but I think the main reason was because I wanted the extra space to run long tube headers plus the adapter plates / sbc mount combo looked hokie to me. I ended up buying weld in mounts off eBay designed for the L83. This allowed me to lower the motor more and set it farther back.
In regard to the Vintage Air system I bought the complete kit with the sanden sd7 compressor and used the KWiK Performance Gen V L83 bracket kit. This setup is really nice. It includes a new power steering pump and a fair price. Wayne, one of the owners of the company I believe, even helped me get my system plumbed and built the PS hoses to fit my truck. I’ve seen guys make the VA kit work with the GM compressor even though VA says it won’t work, but the placement was so close to the frame rail, I preferred the sanden instead. I’ll load pics in a min. Brian
Re: L83 swap 72 C10
The cardboard thing is a replica of the motor mount, I needed to make that so I could get the height and shape I wanted.
#15 |
Re: L83 swap 72 C10
wow. looks good. im not comfortable nor do i feel I can pull fabbing up a motor mount like you. lol i know how to weld but seems very challenging. Looks like ur set up is near identical to mine. (if you make me some that would be awesome lol) Wish you were closer. Headers would be nice. would they fit using ict's billets swap piece and my stock mound or did u just not like the way it looked. my body to is off. Also did you end up using the vacuum pump or did you tap into the manifold. If you tapped in the manifold where did you do it. Sorry my eyes can't see the vacuum pump in the pics
#16 |
Re: L83 swap 72 C10
made the screen bigger lol. power steering pump hoses still look clean. I was worried how running longer hoses would look.
#17 |
Re: L83 swap 72 C10
cornerstone what sway bar did u use?stock?
#18 |
Re: L83 swap 72 C10
sorry bud so many questions? did u swap the oil pan.
#19 |
Re: L83 swap 72 C10
Its all good... I did change from the truck pan to the Holley pan part number 302, It allowed the motor to sit lower in the chassis. I used the CPP sway bars front and rear. Also just to clarify... I didn't fab my motor mounts, I bought them already made, then needed to trim them down to fit for my application. They are only like 80 bucks.
#20 |
Re: L83 swap 72 C10
Talked to wayne yesterday. really nice guy. More than likely ill go with his setup. no point on moving water pump and alternator if there's no need to. Its affordable and seeing it on your truck (brian, (cornerstone) ) i really liked it. Brian, what headers did you use, where did you tap into to get ur vacuum for your brakes oh and what radiator and how did you handle he steam vent. I feel like im cheating, your doing all the research and development (lol) and im just copying.
#21 | |
Re: L83 swap 72 C10
#22 |
Re: L83 swap 72 C10
Hey Brian. So I’m gonna purchase the long tube headers from speed, dirty dingo suggest getting the slider mounts vs the static ones due to making room for headers if necessary. You putting those headers in do you think the sliders are necessary?
#23 |
Re: L83 swap 72 C10
Subbed.
#24 |
Re: L83 swap 72 C10
So ordering speed engineering headers and shipping them to “Jaime” owner of Metaltek manufacturing. I was going to order the weld in mounts he sells and he said He was in the process of making motor and trans mounts for my truck and he asked if I wanted to wait. and when I asked if the headers would fit he said he didn’t know. So to confirm I’m buying the headers and he’s making sure they fit. . It was music to my ears because my frame is powder coated already and I didn’t feel like messing it up. Lol. Plus the vacuum pump can stay. Will update when I get them
#25 |
Re: L83 swap 72 C10
Cornerstone, did you need a high hump to fit the transmission
