#1151 |
Still Learning
Re: LS1 into a 73 cheyenne
Looks Great Alex!
#1152 |
No updates in over a month everything good with truck!
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
#1153 |
#1154 |
the progress is slow as i only work on it once a week for a few hrs. i did finish the fuel delivery dilemma, i did flex lines out of the tank to the regulator hardline out to a fuel filter and out to the fuel rail with a line that is part flex to hardline
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios |
#1155 |
heres a pic of the line up to fuel rail
#1156 |
i rebuilt the fuel injectors with new orings and pintle caps and clips and SS bolts
#1157 |
i completed the dynamat in the cab and i mounted the steering column and steering wheel with the steering u joints, non of this is final in the pic the horn button is also sunk in not in place i more so mounted all this to relief space
#1158 |
i also started on the truck wire harness, i wanted to use the same one but it seems to bulky the nature of the design going from firewall to inside of the cab plus it has allot of unnecessary wires since i deleted wipers heater & AC. its just to big for my needs so i will be getting a new one from speedway and will extend if needed and route away from view as much as possible, i will sleeve it with braided expandable loom and hang it with SS cushion clips. Im soldering and heat wrapping the joints.
#1159 |
for anyone in need i highly recommend this weller WSD51 hardly any wait it heats up in seconds
#1160 |
this is the harness i will use MFG. Part #: 91064022
Speedway Universal 22 Circuit Wiring Harness i will need a new female plug to math the one on my column from ididit ididit Steering 3106050010 Female Wire End Plug
#1161 |
It used that speedway kit when I wired my 1950 F1. Easy to use and only ran into one problem with an error in their diagram, which they walked me through.
Got the 12 circuit kit for my k20 since I didn't use half the circuits when I did the F1. Not as happy with the smaller kit as it just doesn't seem as simple to use.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#1162 |
i mounted the radiator and fan shrouds and a radiator catch tank from moon, i ended up changing my fans and shroud for an aluminum shroud and 2 - 14" fans, with an aluminum replica of the cap. For the radiator mounts i used an aluminum universal kit that i ended up cutting to my needs from Speedway. As for the plumbing from radiator to tank still needs to be done in which case i think i may end up hard lining it
#1163 |
Great info and build!! Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
#1164 |
i mounted the pedals but the gas pedal is not adjusted, on a 92mm Holley throttle body and. The air intakes are not installed but they do clear the space
#1165 |
#1166 |
#1167 |
so i got the harness and i made an aluminum mount from materials i had laying around, some 1/4 angle with a 1/4 flat bar with some spacers to kik it out. I installed it conveniently on the left side of the column more or less where the original location is. i still need to drill and route the wires to their locations, and i will also be making a 12 source fused block with 12 relays for the pcm and accessories related to swap only, i wont be utilising all 12 but i rather have the option, so the truck wiring will be seperate from the LS swap accessories. I will post more on this later as i am still piecing together this set up.
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios Last edited by smokedat; 12-09-2018 at 10:46 PM. |
#1168 |
here's a pic of the crimpers i have i recommend them, there ratchet type and the dies interchange without tools very easy slide in and out
there from Pertronix T3001
#1169 |
Crickets any updates?
#1170 |
Is this project still going?
#1171 |
![]() ![]() Join Date: Jul 2002
It looks like he has not been on here for over a year.
#1172 |
That steering wheel is just too much (in the most badass way).
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#1173 |
so I finally got enough mojo to post an update, don't know how else to word it.
here I am at the exhaust part of it. I got an X pipe and the 10's from flow master, random bends and turbo flanges from amazon and this is what I ended up with.
#1174 |
sections welded out and hanger
#1175 |
side exit
Tags |
73c10, c10, cheyenne, ls1, swap |
