09-24-2018, 12:49 AM | #1 |
Window problem.
So I'm new here. I'm starting back on a project I was doing ten years ago... (70 lwb 2wd BBC). So my window on the driver side won't roll up. It use to when I packed it but now both windows rolling up and down are really ruff. Any quick fix ideas? I'm just trying to focus on the running gear right now. Please, any help is good help!! Thank you so much guys!
09-24-2018, 06:11 AM | #2 |
Re: Window problem.
Pull the door panel and lube the track the mechanism slides it. Sound like it is dry and bound up. Might be a badly worn roller or a combination of both. But it probably got dried out sitting. How are the window seals on the truck? When they get crapped out they let rain water into the door and wash out the lube and/or rust the track.
09-24-2018, 07:08 AM | #3 |
Still plays with trucks
Re: Window problem.
No quick fix. You need to pull the door panel off to gain access to the regulator assembly and the offending parts. You will probably have crud accumulated in the track on the glass and the track on the door shell you can't see that is facing outward that the regulator tracks in but also hardened grease chunks that could be limiting travel and most likely the rollers are crusted up with rust from sitting as well.
I have tried doing this without removing the regulator but freeing up the rusted rollers is next to impossible without being able to get to the side that is shielded by the guide track and getting the crud out from under the rollers is just as tough with them in the way. You might be able to just grease the snot out of the track and make it work with rollers that don't roll but after doing all the work of removing the arm rest, window & door handle and door panel fasteners it is a shame not to do the job properly and spend a few more minutes taking the window regulator out. The four screws holding the regulator to the door shell are usually really tight and are a #3 Phillips head screw. Hit them with WD40 before you start in on them. I found a 1/4" drive socket with a #3 Phillips bit in it on a 6" extension with a 1/4" ratchet work much better than a screw driver at breaking them loose. You can push in on it harder so it is less likely to slip out of the screw and you have more leverage to turn it also. If you still can't get one loose with the Phillips drive the heads are tall enough to get a pair of vice grip pliers on them so you can break them loose that way as well. Once you break them loose hit them again with the WD40 so it can get to the threads for sure. It really sucks to break off a rusted fastener after you get it started to come out of the part. Don't ask how I know that You need to take the screws out of the wing window at the top of the door frame jamb and at the base of the door panel so it can tilt out of the way of the regulator mechanism just enough for you to remove it from the door. It almost makes it out of the door shell without doing this but not quite. Hose down the rollers with WD40 or your penetrating oil of choice then blow them out as you gently try to get them to rotate freely. It doesn't take much rust in the axle area to keep them from rolling. Don't use anything with teeth on them to try to twist the rollers like slip joint pliers as the rollers are very soft and will get damaged. I found the inside of my wiring lineman's pliers have a nice round clearance notch in them that fits just right around the rollers and they give just enough grip to let you get some leverage on the roller to help break the rust up and free the roller from the shaft. I found Home Depot has a pack of 100 zinc plated 1/4-20 x 1/2" long pan head Phillips screws for under $7 and 50 packs of plated versions of the outside serrated star washers that look like what is on the doors for $1.50 so I have been using them in place of the old fasteners when I take out the old ones if they are rusted or get damaged on removal. Sometimes on the same door a few of the originals are still looking great and some look like they were on the Titanic. Maybe different plating as they came from GM or just pure luck of exposure to water but it doesn't seem to matter as to how the threads are. I have had ugly ones come out fine and nice looking ones require extreme measures for removal. Chase all the threads in the regulator, door panel mount points and arm rest mounts with a 1/4-20 tap before you reassemble everything to clean out the crust, blow out the debris then push some silver grade anti-seize compound into the holes and for good measure a dab onto the fasteners as well upon reassembly so nothing ever gets stuck again in the future. Hope this helps.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
09-24-2018, 08:21 AM | #4 |
Re: Window problem.
Use "advance search" to get detailed procedure to remove regulator for repair. Follow them and its pretty easy, or else it can be very hard and frustrating. Its all about removing things in the right order !!!!!!!!!
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
09-24-2018, 08:55 AM | #5 |
Re: Window problem.
When mine did that it was the regulator rollers (or should I say lack of them). Had to buy new window regulators.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
09-24-2018, 09:12 AM | #6 |
Re: Window problem.
Best information by far for disassembly of door. He even makes a note for the small screw below the vent window that pulls the panels together for the 1972 doors.
https://www.youtube.com/watch?v=RY3yXCjqkZE Buy your regulators @ 3 for a door from Classic. Everyone else shows 1 and send you 1 for about the same price. |
09-24-2018, 11:18 AM | #7 |
Re: Window problem.
Sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
09-24-2018, 12:47 PM | #8 |
Re: Window problem.
You can buy the rollers separately if you rivet them onto the regulator yourself. If its the rollers that are the issue. It usually is the rollers.
09-24-2018, 12:55 PM | #9 |
Re: Window problem.
I agree with the others, but one other thing you might check is the window run channel. I've seen them bind up the glass so hard that they would keep it from rolling up, particularly if the felt has big tears in it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-24-2018, 02:33 PM | #10 |
Re: Window problem.
Wow man I came to the right place for help. Thank you so much guys! I might have some further questions for you guys in the near future might even have to pm some of you guys for further info. Thanks again will get back to you as soon as I know more. Thanks again!
Posted via Mobile Device |
09-24-2018, 04:06 PM | #11 | |
Re: Window problem.
You're welcome. I have two virtually new doors via re-building them. If you need anything, so many people here will walk you through it all with pics and steps. I even rebuilt my own vent windows and saved a ton of $$$ R |
09-24-2018, 11:17 PM | #12 |
Re: Window problem.
Nice. Yea that’s why I’m here, for love of these years of trucks and the fun working on them! Thanks again guys will be talking more about it again soon.
09-27-2018, 07:54 AM | #13 |
Active Member
Re: Window problem.
Great information.
