05-14-2004, 02:54 PM | #1 |
properly installing new torque converter
I'm sure this has been discussed before but I was unable to locate any previous threads. I have a new torque converter and a freshly rebuilt th350 that I will hopefully install over the weekend. What is the proper method of installing the converter? I've read from other discussions that it must be installed correctly or the pump will be damaged... Do I need to put trans fluid in the converter prior to install? Any help appreciated!
Thanks! |
05-14-2004, 07:47 PM | #2 |
Fabricate till you "puke"
you should dump a quart of fluid in the converter so it doesnt startup dry. as far as install,silde it on & rotate it till you feel it set in place a couple times(once on the spline, & once on the pump tangs). if in doubt, lay a straight edge across the front of the trans, & measure how far the converter "lugs" are from the front of the trans case....if memory is with me, it should be about 1 1/4". when you set the trans & converter in place, you should have 3/16-1/4" clearance tween the flexplate, & the mounting lugs on the verter.....if you have to force it to bolt up, the converter is not seated into the pump(stop & fix that problem right away!). best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
05-14-2004, 08:45 PM | #3 |
If you don't have it in the pump lugs properly the transmission won't go on the engine. It will hold the bellhousing away from the block. When it fits right, you should have to push the converter toward the flexplate before bolting them together.
05-14-2004, 10:06 PM | #4 |
If properly aligned, the torque converter will alomost push completely against the tranny. I'd put at least 2 quarts or fluid in before installing. Keep newspaper under it in case you spill a little fluid out of the converter when you tip it upright.
05-14-2004, 10:40 PM | #5 |
blood type; Retumbo
you should not be able to fit your fingers between bottom of verter & front of casting. first put 2 Q of fluid in & slowly stand upright
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
05-15-2004, 12:29 AM | #6 |
Thanks for all the great information! Any tips on a brand of ATF?
05-15-2004, 12:34 AM | #7 |
its all about the +6 inches
If you have the cash, go with mobile one. Way better than any 'normal' ATF, and costs quite a bit less than the other full synthetics.
The Synthetic fluid is not only smoother, (for lack of better terms) but it helps tremendously with controlling the temperature in the tranny, which is the #1 killer of an automatic. |
05-15-2004, 12:41 AM | #8 |
Thats all I needed!
thanks again... |
05-15-2004, 11:45 AM | #9 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-16-2004, 12:26 AM | #10 |
John, thanks. I have honestly never heard that one.
05-16-2004, 03:09 AM | #11 |
Never heard that either about voiding the warranty. When I put the last trany in, I dumped a couple of quarts of synthetic in. Haven't had a problem as of yet. Fingers crossed.
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
05-16-2004, 07:36 AM | #12 |
Where does the temp gauge hook into the tranny..?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
05-16-2004, 11:16 AM | #13 |
I have never heard that about Auto transmissions either. The problem I have with that idea is....... how are you supposed to change it? You cannot mix synthetics with normal fluids. Once your torque converter is filled with normal ATF you really have to remove it from the truck to drain it. You can't get even close to all of the fluid from the transmission from the pan.
05-16-2004, 11:33 AM | #14 | |
05-16-2004, 11:50 AM | #15 |
I drill and tap a 1/8 pipe thread drain plug into one of the three bosses that the converter lugs are welded onto to drain the converter. Use a brass pipe plug, as it is lighter than a steel one, for balance. I learned this from a competent trans man 30 years ago, and he did it to every trans he overhauled. Only takes an extra ten minutes the first time and allows complete changing of the fluids. It's messy to drill it the first time full, but the fluid helps flush the drill chips out, not in. If you drill it dry, fill the flutes of the bit, and tap, with chassis grease to retain the chips on the bit, and hold the converter up, so the chips fall down , not into the converter.
69 GMC K10 ..some restoration required....still.. Last edited by Class of 69; 05-16-2004 at 11:54 AM. |
05-16-2004, 12:05 PM | #16 | |
