Old 10-01-2018, 11:45 PM   #1
DKSpringer
Rear Driveshaft Help Please!
Hey guys-
I have a pretty significant clunk when putting the truck in gear. Getting under there, all U-joints appear tight, but I have a lot of slop in the slip splines of the rear driveshaft. Both rotational slop as well as some "alignment" slop.
First, some newbie help with the terminology. I have a NP203 and 14bolt full floating rear axle, stock to my knowledge 1977 drivetrain:
Is this considered a "2 piece driveshaft"? I mean, there are two pieces of the driveshaft connected by splines, but it's not the CV joint in the middle with a carrier bearing style.
What are the pieces of the driveshaft called? To me, a slip yoke referred to the output of the transfer case or the input of the axle, not the rear "slippy" part of the splined driveshaft.
Second, any recommendations on repair options? Is there a chance that the main part of the shaft is OK, and I only need to replace the rear "female spline" part? Should I buy a whole new driveshaft, or pull mine out and take it to a local weld shop?
I tried to grease it, but the grease just went through the zerk and out past the collar. Then, I couldn't get the collar off to inspect. Then, I ran out of time, patience, and beer in no particular order, and came to the all-powerful interwebs for help.
Thanks!
DKSpringer is offline   Reply With Quote
Old 10-01-2018, 11:55 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Rear Driveshaft Help Please!
What you have is typically called a 1pc shaft...you have a,slip joint,yoke,and tube and then another yoke..if the slip joint has alot of wear then you don't have much choice but to replace it...either with used or new parts...
A 2pc shaft usually has 3 u-joints,a slip joint and 2 tubes ...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-02-2018, 10:12 AM   #3
DKSpringer
Thanks for the reply. Any recommendations on where to buy a new one? It seems like most of the places I find are charging an arm and a leg for driveshafts meant to stand up to baja races. Anyone on here have one for sale, preferably near Iowa?
Seems like a driveline shop could weld a new male side of the slip joint to the tube, and I could buy a new female side of the slip joint and possibly save some cash (and have more luck finding parts). Anyone ever done that?
Old 10-02-2018, 11:33 AM   #4
mongocanfly
Yeah, id find a driveshaft shop to help you out...you dont really need a whole new shaft from the sound of it....
Mongo...aka Greg
RIP Dad
RIP Jesse
