Old 10-04-2018, 12:43 AM   #1
chewychevy67
Is this a Drain plug in my torque converter?
I opened up my new torque converter box today and found this plug on the converter. Is it a drain plug or what would this be for? Never seen one like it before. Anyone else have something like this on their converter? I'm hoping it was balanced with the plug in it.
chewychevy67 is offline   Reply With Quote
Old 10-04-2018, 07:28 AM   #2
72LB
72LB's Avatar
Re: Is this a Drain plug in my torque converter?
Looks like a drain plug and also looks like someone rounded off the head of it.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 10-04-2018, 07:30 AM   #3
Getter-Done
Getter-Done's Avatar
Yes.
I have had a few convertors with a drain plug in them.
The early bird gets the worm,
84 Chevy K-20
Old 10-04-2018, 08:08 AM   #4
sick472
sick472's Avatar
That's a drain plug! Typically used when doing a fluid change.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 10-04-2018, 09:34 AM   #5
chewychevy67
Ok thanks. The head is not rounded it just appears that way in the pic
Old 10-04-2018, 12:59 PM   #6
weq92f
weq92f's Avatar
Specs on the converter?
I too had not seen one with a drain plug. Curious that. I would want to manually spin the motor around a few times after install to ensure it isn't contacting anything.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-04-2018, 03:49 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
I've seen where some transmission shops will open a hole when doing a rebuild, to get the converter nice and clean. They usually put in a small plug that uses a hex key, and is about the same mass as the metal that was removed from the converter shell. MOPAR used to have plugs in their converters, back in the day.
~Steven
Simi Valley, CA
Old 10-04-2018, 03:56 PM   #8
chewychevy67
It doesn't contact anything. I spun it already. I don't want to change it as it was probably balanced with it in. It would have been nicer with a Allan key plug but it works.
