Old 10-04-2018, 08:58 PM   #1
slammed57
slammed57's Avatar
vintage air install question
just got a vintage gen iv and was wondering how you all ran you heat/cooling lines, I smoothed my fire wall for a clean look and really dont want to go through the fire wall in the engine bay.I was thinking of running the lines under the fender well then through the fresh air vent cavity , then pull through the vent kick pannel then to the evaporator. Has anyone does something like this? always open to suggestions. thanks , Mike
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 10-04-2018, 09:57 PM   #2
Shinysideup
Shinysideup's Avatar
Re: vintage air install question
On my '51 I went under the inner fender from the front and into the cab under dash high in the kick panel area. I also made my own bracket for the compressor mounting below the heads. It cleans it up nicely so one can seamlessly enjoy the nostalgiia of the truck without distraction.
You will possibly need a few different fittings with different bends and longer hoses but easily do-able. Get some zip ties and some heater hose and try some mockups.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 10-05-2018, 01:10 PM   #3
slammed57
slammed57's Avatar
thanks so much, how did you go into the cab? did use just push the hoses through a rubber gromet or did you use a ac bulkhead with screw on fittings. If you used a bulk head I would image you had to make a larger opening of the vent area to tighten up the fittings?
My 57 current build
Old 10-05-2018, 02:36 PM   #4
_Ogre
_Ogre's Avatar
the 5th gray line is all the wiring for the front lights, ac and fan. 2 wires behind the distributor are temp sensor and starter
shop air compressor timer
Old 10-05-2018, 05:08 PM   #5
Shinysideup
I used 4 grommets sized accordingly. It is all hidden from view with the upholstery.
._____________
Old 10-05-2018, 05:40 PM   #6
joedoh
joedoh's Avatar
vintage air sells grommets and it may work to your advantage to go through the kick panel. I used two mini vintage air systems on the last couple trucks and for whatever reason they like the fittings to come out the SIDE of the system, pointing at the kick panel, all 4 connections. if you tried to go through the firewall like I did you would need a 90 degree turn, and thats harder to plan length for and can pull the grommet this way or that.
does electricity flow more efficiently in a hose than a wire?
Old 10-05-2018, 08:11 PM   #7
67 chevelle
67 chevelle's Avatar
Thats how i did my 67 , remember to seal it well at the firewall , and your kick pannel , otherwise the fan pulls from that side and pulls hot air from the engine compartment , ask me how i know
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 10-05-2018, 09:01 PM   #8
slammed57
slammed57's Avatar
thanks everyone , you all have great solutions , cant tell you how much i appeciate it
My 57 current build
Old 10-06-2018, 02:01 PM   #9
Dan in Pasadena
Dan in Pasadena's Avatar
I also smoothed my firewall and didn’t want a bulkhead to show. It went through the kick panel area, the hoses are in the wheel well and come in as low as possible on the passenger side inner fender.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-06-2018, 02:49 PM   #10
DransportGarage
DransportGarage's Avatar
I'm running mine through the fenderwell. See the 4 holes to the left in first pic and the manifold in the 2nd pic. Hoses will be "grommeted" coming through the firewall, and I made a u-shaped bracket to hold them close to the inner fender. The small hole in the center of the 4 holes is for the trinary switch wiring. The bracket and the dryer are mounted on welded-on studs on the tire side of the inner fender (not shown).
NOTE: Checkered flag in pic is only masked. No paint yet. It will be a ghost flag when done, I hope. New territory for me.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 10-07-2018, 08:45 PM   #11
my56chevytruck
my56chevytruck's Avatar
Hi Buddy, I wish I cold help you, I've only done this on my streetrod. If that would be of any assistance, just call or text me.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 10-08-2018, 12:50 AM   #12
solidaxel
solidaxel's Avatar
Works for me!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-08-2018, 09:49 AM   #13
slammed57
slammed57's Avatar
thanks so much for the pics, looks great
My 57 current build
Old 10-08-2018, 09:51 AM   #14
slammed57
slammed57's Avatar
thanks morrie, i appreceate it
My 57 current build
Old 10-08-2018, 09:53 AM   #15
slammed57
slammed57's Avatar
your fire wall should look real good once painted
My 57 current build
Old 10-08-2018, 12:52 PM   #16
DransportGarage
Thanks, slammed. Shot the copper pearl this morning. Unmasked. I don't want to hijack the thread, so I'll just say, see the "What did you do with your truck today, part 3" thread in a couple of days.
Bob
Old 10-08-2018, 03:21 PM   #17
slammed57
slammed57's Avatar
will do! lookin forward to see it
My 57 current build
