Old 10-06-2018, 08:13 PM   #1
MYOUNG
Brake booster push rod issue
I am attempting to convert my 69 GMC C2500 with Drum/Drum brakes to a Disk/Drum setup from an 84 GMC 2500.
I have replaced the entire system with all new components including the combination valve and master cylinder.
I have everything completed except the push rod in my original 69 booster is too long. I have tried looking for a replacement but none of them look correct. I need a short push rod that fits in my booster.
I considered cutting it down by 1 5/16" to correct the issue but I figured there might be an better way to correct this.
Do I have to switch out the booster now also??
Is there a dual diaphragm type that will bolt up without adapters etc??
MYOUNG is offline   Reply With Quote
Old 10-07-2018, 03:07 AM   #2
vetnat
Re: Brake booster push rod issue
I don't have an answer for you, but just throwing out an idea. How about the push rod from the 84 you got the rest of the parts from?
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 10-08-2018, 12:01 AM   #3
MYOUNG
I think the shape is different on the 84. Unless I've been looking at the wrong pictures online. Mine looks like an exhaust valve.
Old 10-08-2018, 12:05 AM   #4
vetnat
Interesting. I have obviously never had a booster from a 69 apart before.
