Old 10-14-2018, 05:02 PM   #1
Warrens69GMC
Warrens69GMC's Avatar
Axle ratio?
Whats the 12 bolt axle ratio?
12:32, 12:42?
1979 Suburban, 454, TH400, 12 bolt and 7000gvw
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-14-2018, 05:35 PM   #2
geezer#99
geezer#99's Avatar
Re: Axle ratio?
Clean it off and have a better look.
Usually the ratio is stamped with the ring gear number first and the pinion gear second.
That might be a part number you’re looking at.
Old 10-14-2018, 09:23 PM   #3
mongocanfly
mongocanfly's Avatar
Re: Axle ratio?
im with geezer....but if 12:42 is correct (even backwards) that works out to 3.50:1....since you've got the cover off itll be real easy to do the ol spin and count rotations
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-15-2018, 01:41 PM   #4
Keith Seymore
Keith Seymore's Avatar
Re: Axle ratio?
Your choices are 2.76 (base), 3.07, 3.40 or 3.73 (optional).
Teeth are:
2.76 = 17/47
3.07 = 14/43
3.40 = 10/34
3.73 = 11/41
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-15-2018, 01:55 PM   #5
Keith Seymore
Re: Axle ratio?
I show a 8&1/2" ring gear 3.42 that's 12 and 41, but since that is not one of the choices above that would imply it's not the original axle.
K
1979-1986
1986 - 2019
Old 10-15-2018, 02:54 PM   #6
Killer Bee
Killer Bee's Avatar
Re: Axle ratio?
Warren, is it a C10 or C20? Keith posted 7k gvw options in C10 based on your post..
is it possibly 4.XX ratio 3/4t axle? I recall Keith posting recently about gvw groupings, maybe a factor here?
simplest thing to do at this point, is clean off a spot on the ring gear, mark a tooth with junk yard pen, and count..
if you can, do the same on the pinion.. maybe a mirror and light will make it possible..
compare your numbers to the factory options Keith posted and see if you're close..
if you're unsure due to access to the pinion teeth, count revs to see what neighborhood you're in..
good luck!
Old 10-15-2018, 04:21 PM   #7
Warrens69GMC
Re: Axle ratio?
Its a 5 lug 12 bolt. I will get under there again with some rags and brake cleaner to see if I can find more numbers.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-15-2018, 09:33 PM   #8
Warrens69GMC
Re: Axle ratio?
Getting back under found 11:41 = 3.73
Thank guys!!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-16-2018, 12:08 AM   #9
Tarm
Re: Axle ratio?
Are you planning on changing gears or just looking for info purposes? Is it me or do a couple of those ring teeth look a bit rough? Maybe its nothing.
Tarm is offline   Reply With Quote
Old 10-16-2018, 12:13 AM   #10
Warrens69GMC
Re: Axle ratio?
I was more curious than anything, this Suburban has set for a while, so it needs new fluids anyway. The SPID is long gone, so that was not an option.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
