Few questions and a YouTube video
I’m wanting to lower my truck with 2 1/2 drop spindles in the front and have bags in the rear running on a T line with a air inflation valve coming out of my roll pan. No compressor or tank. My question is is there such thing as a leak proof system, and which bags should I run so that I’m not stretching the bag too much if that’s possible. I know 2600 bags extend to like 9” and the titan 2500s extend to 11.5. I don’t want to be so low that I’ll I’m dragging headers just even and be able to throw something in the bed and level it back up. https://youtu.be/b6IwMEQoWx8 Here’s a link to my truck. And does anyone have a picture of their truck running what I’m looking to do? Thanks guys!
![]() Join Date: Aug 2004
Re: Few questions and a YouTube video
I have 2500 bags on the rear of my truck and the schrader valves in the license box like you, I don’t think there is anything like a leak proof setup, the tank and compressor is the way to go to keep them aired up properly without checking regularly.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#3 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
That way air can't move back and forth between bags when you go around a corner.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-15-2018 at 10:14 PM. |
#4 | |
![]() Join Date: Feb 2013
https://www.summitracing.com/parts/art-11334099 https://www.summitracing.com/parts/art-32000001 Front: 2" spindles, 3" springs; the rear can go about 3" lower and still have decent ride quality. Last edited by mfm3; 10-16-2018 at 01:36 PM. |
from years of experience working on heavy duty trucks with air brakes and air bags, there is no leak proof system..
but I'll share some tips to getting close, possibly close enough to run with minimal issues without an onboard compressor.. keep in mind that you may want to maintain enough ground clearance to get home in the event of total air loss ![]() minimize the number of fittings and length of plumbing.. adapters, tees, bushings, etc all add leak points.. use high quality compression fittings without swivels.. push-lock and swivels leak.. leak test everything at maximum rated inflation, soap n water, snoop, etc.. repair or replace as necessary.. two home runs from each bag to it's own schrader would probably be the least amount of connections and shortest runs.. and as mentioned above, allows for balancing loads as well as launch ![]() don't allow bags to deflate completely.. this distorts and stretches mounting seams on the ends of the bags.. may also consider using dry nitrogen, denser gas escapes less through rubber, more stable pressure during temperature changes, and dry gases contain less contamination to promote corrosion and oxidation on metal parts.. I have this little rig for reservoir shocks, works like a champ and lasts a looong time.. notice the Schrader 556 low-loss valve on my gauge manifold.. the manual valve stem depressor t handle allows precise pressure management without the 'pssst' loss when removing push-on valves.. pro tip - although valve has a hex, these handle much higher pressures than needed for automotive use and can be adequately tightened by hand so not to distort the brass seal washer ![]() good luck! ![]()
I started out with nothing - and I still have most of it |
Torsion bar only and bags. Last pic bags all around. Firestone fronts 2600, rear 2500
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Last pick is 225/70/15 close to what the 245/45/18 thats on it now. Torsion bars only. Lil more than 2" drop front
Thanks guys for all the input and I haven’t even thought about using nitrogen that’s a good idea. Thought about using these https://www.ebay.com/p/63-72-Chevy-G...b4227dffedb270 nice trucks guys. I’ll defiently have a portable air tank on board and that’s reassuring it hardly lost any air during that period. I’ll get some blocks built for the back
#9 | |
#10 | |
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-17-2018 at 09:02 AM. |
^ sure, I don't see why not..
seems like a viable solution as long as it has the capacity required for the bags.. tucked away under the seat in case of air loss away from home.. good luck!
I was sure I had found some 3 inch drop spindles on amazon for $200 but I didn’t take into consideration the size of my wheels. So on the prowl again. Does anyone have a picture of a truck with just lowering spindles on the front?
Which brand of drop spindles is everyone liking?
Early Classic Enterprises, Classics Performance Parts are the front runners. CPP has horable service though, great parts. ECE has always been good to me for parts and help.
#15 |
I like CPP's parts and always buy from Summit; can't beat their price, free fast delivery and great customer service. The link shows two CPP options (2'' and 2.5" drop). The 2" "modular" drop spindles require additional caliper brackets (2nd link) but offer the option of running OE calipers or aftermarket big brake kits. I believe this is why they are referred to as "modular".
https://www.summitracing.com/search/...rder=Ascending https://www.summitracing.com/parts/c...7dbk/overview/ |
#16 |
Well guys I got some Jeep springs for the free yesterday and man they lowered it quiet a bit. Then I threw my wood in the bed just to see what Itd be like and they don’t take great to weight at all. Gonna ride these for a while and then make the switch to bags.
