Old 10-15-2018, 08:24 PM   #1
anew4961
big block 402 engine brackets
Just bought a 402 for my 69 truck don't remember mounting bracket location and engine came with some of them this one has alternator on passenger side i dont think thats right maybe it is
need photos or help so i know what to buy thanks
anew4961 is offline   Reply With Quote
Old 10-16-2018, 07:40 AM   #2
Mike C
Mike C's Avatar
Re: big block 402 engine brackets
The truck pulleys and mounting brackets are the same as the 65-68 big block Chevelles if you are looking for a source for replacements.
But you are correct, passenger side alternator setup was for the long water pump that was never installed on 68-72 big block trucks. Sounds like somebody swapped a big block into your truck from a 73 and up truck donor or 69 and up car donor.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-16-2018, 08:09 PM   #3
anew4961
Originally Posted by anew4961 View Post
just bought a 402 for my 69 truck don't remember mounting bracket location and engine came with some of them this one has alternator on passenger side i dont think thats right maybe it is
need pictures of ac brackets have the other figured out
Old 10-16-2018, 08:48 PM   #4
Mike C
Mike C's Avatar
Google images for 68 Chevelle ac brackets should find it.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-17-2018, 01:52 AM   #5
ho70
ho70's Avatar
this is a pic taken from another member...they are the stock 72 ac brackets
ho70 is offline   Reply With Quote
Old 10-17-2018, 11:09 AM   #6
ho70
ho70's Avatar
and the ps and alt brackets
Old 10-17-2018, 12:37 PM   #7
anew4961
Thanks that was helpful
Old 10-17-2018, 02:00 PM   #8
ho70
ho70's Avatar
one more
Old 10-17-2018, 02:03 PM   #9
ho70
ho70's Avatar
ps brackets
Old 10-17-2018, 08:26 PM   #10
anew4961
ps brackets
the ac brackets were those original bracket
Old 10-17-2018, 11:38 PM   #11
ho70
ho70's Avatar
yes
Old 10-22-2018, 10:40 PM   #12
anew4961
correct its a car engine that was sold as a truck engine price wasn't bad so i can't complain
Old 10-22-2018, 10:41 PM   #13
anew4961
ps brackets
where does the ps tank mount thanks
Old 10-23-2018, 09:10 AM   #14
Mike C
Mike C's Avatar
It’s mounted to the driver side fender.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-23-2018, 10:06 AM   #15
davepl
davepl's Avatar
Those are mine which would make them '70 but I imagine all the same!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-23-2018, 10:12 AM   #16
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
From a dry run I did. Shows all the brackets. It doesn't show the retainers/clamps near the evap. I have assembly instructions if you need it, down to the bolt type.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-23-2018, 09:34 PM   #17
anew4961
need a photo of it thanks
Old 10-23-2018, 09:47 PM   #18
Mike C
Mike C's Avatar
Found a thread using search box at top of page with check box for this site selected. There are some included that had a bracket from radiator support, but the big block trucks I have owned (70 and 71)have had it like on fender.
http://67-72chevytrucks.com/vboard/s...d.php?t=735249
44 Willys MB
52 M38A1
64 Corvette Coupe
