10-11-2018, 04:14 PM | #1 |
Do all Supers have upper and lower molding's?
I'm looking at a 71 Cheyenne Super that seems to be a very original unmolested truck. All the interior appointments check out but I've never seen a Super with no lower molding's. I looked up inside the lower bedsides, no original trim holes. Truck is all red with what looks like just one repaint, no sign of two-tone anywhere. The SPID is damaged and worn to the point it's almost completely unreadable. I can make out YE in one of the code boxes but nothing else. Are there any other codes that start with YE? Solid color Supers do exist, yes?
Thanks, Steve weim55 Colorado |
10-11-2018, 04:18 PM | #2 |
Re: Do all Supers have upper and lower molding's?
Solids Supers exist. Post that SPID and I bet we can help.
10-11-2018, 04:26 PM | #3 |
I have never seen a documented super that did Not have upper and lower trim
Unless it was a step side or cab and chassis motor home |
10-11-2018, 04:54 PM | #4 |
Unfortunately the SPID is so bad you can see nothing in a picture. Can just barely make out some of the codes with a spy glass on the left column box, nothing on the right.
Truck is a long box fleet side 1/2 ton. YE9 is the call out for a Super, yes?? Steve weim55 Colorado |
10-11-2018, 10:15 PM | #5 |
SWB 4x4 Collector
I agree with Chevyland.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-11-2018, 11:17 PM | #6 |
I've heard full trim was standard on a Super. Doesn't mean none were ordered without it. There are 2-3 different codes for a Super. YE9 is the most common.
Look for a build sheet on back of or below the seat. If it's like my Super, the sheet is on back near the bottom, so I have to pull the seat first - The sheets are very fragile.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-11-2018 at 11:28 PM. |
10-12-2018, 05:45 AM | #7 |
No Stepside or Cab & Chassis Supers with side moldings. All Fleetsides upper and lower. If any do exist they are COPOs and a rare exception
10-12-2018, 06:21 AM | #8 |
YE9 is the only RPO for a Cheyenne Super.
Wording doesn’t matter - only the three characters. Some Canadian trucks have listed the terminology for Z84 as “Cheyenne Super Truck” or some oddball thing like that - but it was indeed a Cheyenne only. If no YE9, no Cheyenne Super. |
10-12-2018, 12:57 PM | #9 | |
Here's a variance in description, post 36 "Cheyenne Super Spor" http://67-72chevytrucks.com/vboard/s...=729469&page=2 Post 112 is interesting. A rare variance for "YE9" code. Has the "Super Truck" you mentioned: http://67-72chevytrucks.com/vboard/s...=729469&page=5
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-12-2018 at 01:11 PM. |
10-12-2018, 01:05 PM | #10 |
Not trackin, Post 12 in that link is a YE9 Cheyenne Super, like all Supers. What other 2-3 RPOs are you talking about in Posts 6 and 9 above?
10-12-2018, 01:18 PM | #11 | |
Post 36: It's your post, just a variance in description. Post 112 (I wrote 119, that's wrong): It's similar post 12, but it reads 1YE9AB instead of 1YE950.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-12-2018, 01:31 PM | #12 | |
Edit - btw, Keith wrote up a great explanation of what those extraneous characters can sometimes mean. Worth a look, I found it very interesting. Last edited by jocko; 10-12-2018 at 01:49 PM. |
10-12-2018, 09:55 PM | #13 | |
I can't quite reach the write-up, but I see "The additional characters are either ECL codes, which provide additional detail about the RPO, or dummy characters filling the spaces after the added codes fell into disuse." And "ECL Exception Control Letter". That alone explains a lot.
10-12-2018, 10:22 PM | #14 |
To answer the original question, on YE9, Cheyenne Super trucks the upper and lower molding are not called out on the SPID, they are included in they YE9 option. Yes all SWB and LWB Cheyenne Super trucks had the upper and lower woodgrain moldings included in the option.
All supers had, headliner w/ chrome plastic trim, wood grain overlay on the dash, woodgrain door panels, 72 had stainless cover on the tailgate handle. Pictures would help. http://67-72chevytrucks.com/vboard/s...d.php?t=729469
10-16-2018, 10:10 PM | #15 |
Turns out the truck in question is NOT a real Super. Trying to find ways to read the damaged SPID found if I daub a little moisture over the type I can read some areas. VIN on SPID does not match the truck. Stunned as she was last plated in 1985 and is 100% bone stock. Someone must have had access to a complete parts vehicle and got EVERYTHING for the swap back in the day. Another tip off was the factory black mat under the carpet.
Thanks for all the replies and info! Steve weim55 Colorado |
10-16-2018, 10:15 PM | #16 | |
10-16-2018, 10:20 PM | #17 |
Yes, the headliner is there and black in color. Glove box door is black as well. That's the one thing I thought was fishy as red body and dash would have a red glove box door (?)
10-16-2018, 10:23 PM | #18 | |
These trucks are OLD - my Super has a rubber mat because someone replaced the carpet - so you never know. Curious what your other clues were. Too bad the SPID is bogus. Just look at it as "freedom to build it how you want!" Can you confirm your cab VIN is riveted with the correct rosette rivets? If so, what's the VIN? What was the VIN on the SPID? If you post the SPID, even if it's unreadable, you'd be surprised what folks can do with photoshop etc. Often monkeying with the contrast and brightness yields a more readable pic. Anyway, if SPID no matchie, kind of a moot point, but still interesting. |
10-16-2018, 10:24 PM | #19 | |
If the cab has a headliner, it is likely at LEAST a Cheyenne as a headliner is not an easy thing to add. Cheyenne and Cheyenne Super were the only ones with headliners. Got any pics of this truck? |
10-16-2018, 10:31 PM | #20 |
Once those #s didn't match I worried the truck might have a sketchy past (stolen). VIN plate is unmolested and frame VIN matches. 2nd owner registrations back to purchase in 1974. Fender emblems look original and placement is perfect compared to others on this site. Maybe Custom Deluxe emblems use the same stud holes (??)
10-16-2018, 10:40 PM | #21 |
The seat is still the original black and white houndstooth, std. Cheyennes are all vinyl, correct ? Truck is still in the widows garage. Daughter doesn't want me taking any pictures, not sure why, but have to honor her wishes until I get the truck unburied and out of there.
10-16-2018, 10:49 PM | #22 |
Ah, I understand, no worries. When you say black and white houndstooth - what color is the vinyl remainder of the seat (outside the cloth)? Black or parchment? If parchment, that's a correct Super seat cover. Supers never had black vinyl with houndstooth seat covers. Either could be had aftermarket, but only parchment vinyl with black/white houndstooth is original. Supers with a bench could only have a parchment, olive, or blue seat cover(with houndstooth insert - it was called "custom cloth"). Bucket-equipped Supers could have any of the normal vinyl colors. And you are correct - a Cheyenne would have had the all vinyl seat with scrollwork.
10-16-2018, 10:50 PM | #23 |
My red supers both had black glove box doors.
10-16-2018, 10:51 PM | #24 |
The headliner in a super would not be black.
10-16-2018, 10:54 PM | #25 |
Nope - if it has a headliner, it was very likely born a Cheyenne or a Cheyenne Super. If a Custom Deluxe, someone would have had to have added the headliner.
