Old 10-16-2018, 07:48 PM   #1
Rgarriott51
51 GMC Truck radiator bracket measurements
Hey GMC guys. I had to fab up the bottom section of the radiator support due to it being rusted out and need to know what the measurements are. Hight and width.
Rgarriott51 is offline   Reply With Quote
Old 10-16-2018, 09:35 PM   #2
MARTINSR
MARTINSR's Avatar
Re: 51 GMC Truck radiator bracket measurements
You are going to need to show EXACTLY what you need.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 10-17-2018, 12:54 AM   #3
e015475
e015475's Avatar
I have a 49 GMC. Post a sketch of the dimensions you need and I will get them for you..
Is that the radiator you're going to use? Looks like a Chevy not a GMC. The cap is in the wrong spot. A GMC has a gooseneck on the side of the top tank.
e015475 is offline   Reply With Quote
Old 10-17-2018, 09:50 AM   #4
Rgarriott51
Thanks for the reply guys. I need from the frame rail up to the top and from the bottom middle up to the top.
Yes that us the radiator i will be using. Disnt realize they were different until i started fabbing stuff up, but i think it will clear the cap bracket. Just goin to b a pain in the rear if i need to add or do a radiator flush.
Old 10-17-2018, 11:48 AM   #5
e015475
e015475's Avatar
Here ya go.........
The first is the top of the frame rail to the upper two bolt holes on the radiator support
This is the measurement from a line drawn through the upper bolt hole of the radiator support to the bottom of the radiator support (on the inside of the support - add material thickness if you want it to the outside)
Between the radiator support and the frame rail, there are shims to align the front end of the truck to get the fenders and hood fitting properly. Your drawing looks like you want a dimension down to the cross member that supports the radiator support. This is a measurement from the reference holes in the support to the cross member where the lower bolt goes through it from the support
This is the setup I used to do the measurements - you can see the closeout piece that goes on top of the radiator support. This is the part that will interfere with a Chevy radiator installed in a GMC unless the radiator is moved back so the neck clears the support.
Here's a photo of an original GMC radiator in a stock truck. The GMC engine was a little longer than the Chevy, so GMC made room by pushing the radiator into the core support. This is why there is a gooseneck filler on the GMC and not the Chevy
Hope this helps you some
Old 10-18-2018, 01:22 PM   #6
Rgarriott51
Wow. Thanks for all those measurements. That helps out a ton.
Old 10-19-2018, 10:10 AM   #7
e015475
e015475's Avatar
You're welcome
Post up or PM me if you need anything else
Phil
