Old 05-16-2004, 05:46 PM   #1
guyryan100
guyryan100's Avatar
trouble removing steering box
unbolted from frame without trouble and from steering column but I cannot remove the gear box from the rest of the steering system - have removed the large hex nut but cannot get things moving - any tips?
--Ryan
guyryan100 is offline   Reply With Quote
Old 05-16-2004, 06:50 PM   #2
Sweet72
Sweet72's Avatar
Manual or power streering? Sounds like you're trying to remove the pitman arm from the steering gear. You'll need a pitman arm puller, a tool available at auto parts stores for about 20-30 bucks. You can remove the other end of the pitman arm from the tie rod center link eye with a pickle fork.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
