![]() Join Date: Sep 2002
Bed Front Panel Bolt Direction
Quick question...
What direction do the bolts that attach the front panel to the bedsides point, to the front or rear? |
Re: Bed Front Panel Bolt Direction
As far as I know they push through the panel towards the cab.
Nuts inside bed according to assembly manual.
Nitro |
Yep, that's what I found too after finally thinking about looking in the AIM. (Although they look better going the opposite way...)
![]() Join Date: Aug 2018
I suggest putting the nuts inside the bed. When my dad and I put together his 64 bed, it was my idea to put the bolt heads in the bed, but then after we attached the bed one of the bolts scratched the back of the cab and we had to carefully cut the end off it with a hack saw blade. Those bolts come closer to the bed than I expected.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Good point. I wound up installing them as it shows in the AIM.
Moderator
![]() ![]() Join Date: Aug 2011
I just looked at the Mark-K assembly instructions and that's what they show. Nuts on the outside of the bed, screw heads inside the bed.
I went and looked at the bed (Short, Step-Side) I bought for my truck today. There are 5 bolt's on each side in the front. The top two are rear facing and are not seen from the bed. The bottom three are facing the cab.
View "A" in the 1960-1966 Chev/GMC Truck Factory Assembly Instruction Manual also shows this bolt configuration. |
Moderator
Correct-a-mundo.
