Old 10-26-2018, 12:15 PM   #1
whateverpratt
Which C20 rear coil springs?
I'm looking at my options on rock auto for getting some coil springs, and I'd like some input from those who are familiar with these different springs about which I should get.
Here's the ones I'm considering with the load rates:
ACDELCO 45H3018 950
ACDELCO 45H3075 1335
ACDELCO 45H2011 1700
ACDELCO 45H2012 2900
This is for my work truck that regularly carries 1,000-2,000lbs of tools and chemical.
I'm the type of guy that likes to over build, but I'm wondering if the 2900 pound spring is too much and maybe I should stick with the 1335 or 1700. Thoughts?
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle
NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778
Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775
whateverpratt is offline   Reply With Quote
Old 10-28-2018, 11:56 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Which C20 rear coil springs?
If you use it...bag it. You can air up when need and lighten the springs when empty for a nicer ride. I have Ride Rights on my 1 ton and it helps ride and load.
Firestone 2600s
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
