Old 10-30-2018, 12:19 AM   #1
Miller's Metal
Miller's Metal's Avatar
64" spring swap ?
Anyone swap them under a 1972 K-10/20.
Miller's Metal is offline   Reply With Quote
Old 10-31-2018, 12:02 AM   #2
'63GENIII
'63GENIII's Avatar
Re: 64" spring swap ?
Check out the link in my sig. Long thread and on a '63 but its basically the same process except I think that DIY and ORU make hangers specifically for the 67 - 72 trucks which might make it easier.
Skip the front axle part.
The rear axle goes pretty easy.
FWIW, most will stay away from the 1/2 ton stuff as they have a tendency to "W" or bend. So Ive been told. I ended up swapping my 1/2 ton springs for 3/4 ton and am still contemplating bags. The 1/2s (while cheap) get onto the overload just a little too easily for my liking.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-31-2018, 04:27 PM   #3
Miller's Metal
I've looked through your thread a few times,nice work! I have the same blazer tank just waiting to go in with the springs.The springs that I have are the 3/4 ton 4x4 version. Looking at my front hanger if I move it forward on the lower frame rail rivets. Swapping the back hole for the front. It will move it forward 6.5'' and down 2". Is that about where yours ended up? Also for the rear I'll use a shackle flip compression style two plate design like you used,so I can adjust the height for the rear.How far down did your front shackle end up from the stock hanger? Did you gain any lift from the spring it self? Thanks,Gary
Old 11-01-2018, 12:17 AM   #4
'63GENIII
'63GENIII's Avatar
Hey Gary,
I'll try and get some pics off of my computer to show the relationship of the new front hanger vs. where the old one was. I should have taken measurements but was in more of a hurry and trying to make sure that the axle was straight consumed most of my attention..
I do remember clamping the hangers onto the frame and loosely setting everything down onto the axle to estimate what the sag would be several times to mock up the positioning of the hangers before drilling. It was a lot of eyeballing. Not very scientific.
As far as lift, I do not have 4-1/2" blocks anymore and the truck sits with about 3/4" rake. If I had to guess, total lift is around 5".
Chris
'63 k15 long step
Old 11-01-2018, 12:22 AM   #5
'63GENIII
'63GENIII's Avatar
Your 6-1/2 forward sounds about right. If you look at the larger hole that lines up with the crossmember, you can see it moved forward quite a bit. I think that may have been where the old grease pin may have been centered.
On mine IIRC, the front spring eye moved toward the top of the frame a few inches.
The shackle flip seemed to provide most of the lift. More so than the front eye placement.
Chris
'63 k15 long step
Old 11-01-2018, 11:22 AM   #6
sweetk30
sweetk30's Avatar
the 64" spring center pin is centered .
just do the math and move the hanger that much for each . its how i did it years ago on a not finished project .
also the normal is rear hanger is .5" less that the center pin to eye length . this is to start the shackle on its movement path .
the project i did the swap on was a 77k30 truck . fyi the 20 gal tanks dont fit anymore after this swap . so it would be shorter 16 gal tanks or blazer/burban tank swap in the rear .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
