#176 |
60-66 Nut
Re: Johns 66
Upgrading to front disc brakes does not have to be expensive. If all you want to drop the front is 2", then all you need is a set of stock '71-'87 spindles, stock rotors and calipers and a set of 2" dropped springs. Oh I almost forgot about the tierods. If you can find the original '71-'87 steering linkage, that will save you from having to buy the $50 aftermarket tierod adapters.
#177 | |
![]() Join Date: Apr 2017
Re: Johns 66
Skinny G...I appreciate the information....Im not going to track it...sure I may drive it kinda fast in a straight line from time to time but that's about it....definitely not gonna be a racer. I highly doubt that that there will be much weight ever put in the bed, I have some Ash wood that I am going to mill for the bed along with some polished stainless strips that I got from Mar-K. My question would be what would most consider a "Quality' set of springs? Does this mean they need to be dual rate? |
#178 | |
Re: Johns 66
The only things that I probably will ever pull is my boat or a small trailer with either my bike or lawnmower which I don't thin would be too terribly bad.....if I was going to pull for longer distances then I would just use my newer model Silverado to do that...Although I have been looking at a 19 GMC AT4 with a 6.2L kind of high right now so may wait on that to get a used one in a couple of years. I really appreciate the info on the brake changeover..I have a couple of junkyards around that I will hit up and see what they have....Someone told me that I could simply sway the whole cradle but if all I have to do is change the spindles, rotors and calipers, plus some tierod ends etc...Im thinking that may be the way to go. |
#179 |
Re: Johns 66
I also checked with Advanced plating for an estimate on having my grille chromed....They said they had a recent fire and it will be awhile before they are back up and running but the estimate to chrome the grille and headlight bezels was almost 1600.00....Very Stout price
#180 |
Re: Johns 66
By "quality spring" I just mean something with a reputable brand name on it. Cheap springs sag a whole lot quicker over time.
A "dual-rate" or a "progressive" spring has you riding on softer spring rate for comfort, but the rate increases the more it is loaded, which helps carry that load better. Progressive (or dual rate) might be a good compromise.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#181 |
Re: Johns 66
Picked up some OEM NOS original door rubber gaskets today from Mike Cofield. I think these will be great to keep the windows sealed and from rattling..Although I am a ways away from taking her to the beauty shop its always good to get great parts...especially NOS parts. Thanks Mike really appreciate it
#182 | |
Re: Johns 66
Thoughts? |
#183 |
Re: Johns 66
I am a big fan of spindles - it helps maintain proper suspension geometry and travel (as proper as it can be for the 60's).
#184 | |
Re: Johns 66
#185 | ||
Re: Johns 66
Here is my thinking at this point... I have had estimates from QA1 to change the entire front and rear for about 5000.00...while coil over front and rear with disc would be cool but cant justify 5k for the suspension plus would have to buy new wheels and tires... there are a couple of different ways that QA1 has Jegs seems to have the best price I found so I used their links https://www.jegs.com/i/QA1/122/52898/10002/-1 https://www.jegs.com/i/QA1/122/RCK52611/10002/-1 https://www.jegs.com/i/QA1/122/R210-250/10002/-1 https://www.jegs.com/i/QA1/122/52611-D750/10002/-1 Ride Tech has a suspension kit for about 2500. front and rear. https://www.jegs.com/i/QA1/122/52611-D750/10002/-1 This kit does have both front and rear with a front sway bar.....but does not include rotors, brakes etc..... So based on these two I have to go another way...Ride Tech does offer front stock springs that are dual rate, and rear 4" drop springs that are dual rate that I could put in with my stock set up for about 475.00 I checked with ECE and they have a system for around 1300.00 https://www.earlyclassic.com/node/1195 https://www.earlyclassic.com/node/1267 but with stock front springs or springs from about 115.00 a set The brake upgrade can be done after I am done with the cosmetic work so I am thinking I can still do research on this upgrade....Just have to decide which springs to go with. On a side note I did get my quotes for chroming the grille...WOW from 2000.00 down to a 1000.00. There is a place that is local ( in the state) that does this type thing and were the cheapest at around 1000.00 depending on condition once it is stripped. |
#186 |
Re: Johns 66
I have been receiving quotes today from the many requests on having items chrome plated.
I did a search of local and not local business and here is what I have received. Paul's Chrome in PA 1500 for the grille, 250 each for the bezels Advanced Plating in Tn 1200 for the grill and 175 ea for the bezels Graves Plating in Al 1000.00 for the grill they didn't mention if that included the bezels and am waiting on a response from them El Paso Electroplating 295 for the grille, 25 ea for the bezels, Ruben stated that if I wanted "Show Quality Chrome" that it would be an additional 30%....which is way cheaper than any of the rest. I reached out to a member here that had his grill plated by El Paso and am waiting on his response to see what his experience has been with them. I know you get what you pay for but this will not be a trailer queen but I do want it to look nice. Thoughts? |
#187 |
Re: Johns 66
Ordered a few things today for the ole 66.....Mainly door stuff
https://www.americanclassic.com/1964...ctinfo/03-806/ https://www.americanclassic.com/1964...ctinfo/03-568/ https://www.americanclassic.com/1960...tinfo/03-013B/ I read some threads where these items from this company were highly recommended, especially the press on door seals. I did find a place that I can go look at some 1st gen truck....supposedly there is a lot of them just sitting in a field...gonna try and run by there tomorrow and see what's there. From what I understand they are complete truck but time will tell |
#188 |
Re: Johns 66
Went to the junk yard today to see about the 1st Gen trucks....Only had 2...one was partially fixed and it was plated with gold based on the price he wanted. The other one he had was a mix matched truck from parts from several different trucks...not what I would say would be a good candidate to even mess with...…
BUT...I did stop by and see Mike today and was able to pick up the NOS Fan Shroud....pretty neat to be able to buy a NOS part for the ole 66. My original is cracked in several places and I have tried to plastic weld it back with no luck so this was right on time...Thanks Mike. On a side note I do have another adventure planned for next weekend to look at some NOS parts...….we will see |
#189 |
Re: Johns 66
Gathered some more parts today....Luckily I was able to get some NOS rocker panels and a set of NOS Emergency Brake Cables...….Cables are hard to take a picture of the cables.....so you just have to trust me..lol
#190 |
Re: Johns 66
Well folks and any who may be following...I went shopping and was able to get some things....some I needed ...some I couldn't pass up.
Here is kinda a list of things I bought....Ill post pictures ...not sure how many you can put per a post. All the stuff is for a 60-66 C10 some specific for 64-66....I guess some things they used all 6 years. So here we go...… A set of NOS door for my 66 C10....they are just the shell but all the original stuff will fit. NOS front fenders. both sides NOS Script Valve Covers Passenger Side NOS Inner Fender NOS Outside Door Handles NOS, Tail Light and Park Lamp Bezels NOS Park Lamp Lenses NOS Back Up Light Bezels NOS Molding Clips...Top and Bottom NOS Dual Pulley...for when I add power steering NOS Window Crank Handles NOS Wiper Arms??? Its the ones that attach to the motor Automatic Steering Column ...Didn't need but couldn't pass up Deluxe Steering wheel....Didn't need but couldn't pass up ALSO I Bought a 402 Big Block with a 400 Tranny....all accessories including AC compressor...Not sure what I will use it for but who passes up a 402 big block These are the big things plus I got a few smaller used item |
#191 |
Re: Johns 66
More Pics...Its very slow downloading for some reason so I will try less pics per post... Auto Steering Column and Deluxe Steering wheel......Didn't really need because I already have this but couldn't pass up because they are rare
#192 |
Re: Johns 66
Here is a pic of one door.....didn't want to unpack both of them but you can see what it is...So a new set of NOS Doors.....So stoked!!!!
#193 |
Re: Johns 66
Front Fenders...Again I only took pics of one because I didn't wanna unpack both
#194 |
Re: Johns 66
Wow...super jealous John! The doors and the steering wheel are nice. I need to get a "new" SW...I need to figure out if I want an OEM one or an OEM look but slightly smaller version...if it exists. Those doors...WOW
#195 |
Re: Johns 66
Inner fender....I picked this up for Yelmer because I knew he was looking for one.....Mikes a good guy and has helped me tremendously throughout my build so this was the least I could do for him.
#196 |
Re: Johns 66
Some other stuff …..Valve Covers, Door Handles, wiper arms etc
#197 | |
Re: Johns 66
I didn't need them but couldn't pass up New Doors, or New Front Fenders. I feel very fortunate to have been able to go and purchase these items. The other items you never really know about...they are not making them anymore so I think when you do find things like this that you have to get them while you can. |
#198 | |
Re: Johns 66
#199 | |
Re: Johns 66
I did find a place near Atlanta that is willing to work with me on getting my rust repaired and is willing to do it in stages for me...I am planning on going over to talk with him after the holidays...fingers crossed. |
#200 |
Re: Johns 66
That's great news...Their pictures look nice...I would love my grille, headlight and parking lamp bezels along with my bumpers done....Can't wait to see what you think!
I found this thread from years ago, looks pretty good. http://67-72chevytrucks.com/vboard/s...d.php?t=495482 Last edited by roll_the_dice; 11-20-2018 at 11:43 AM. |
