11-03-2018, 08:05 PM | #126 |
Re: My winter project
I rounded up some straight down exhaust manifolds. I could use some help from you guys with stock AC. I have the brackets, compressor and some bolts but not sure of right placement.
Thanks 7D2N
Just for the fun of it |
11-27-2018, 08:23 PM | #127 |
I finely got the AC brackets in the right place and now ready for start up and break in, just a little fuel and hope all is good.
7D2N
Just for the fun of it Last edited by 7D2N; 12-06-2018 at 08:46 PM. |
04-05-2019, 10:15 PM | #128 |
I may have to rename the thread to (My many winters project) I'm getting things done slowly and a lot of boring stuff but I've found out that the phrase rebuilt means....do-over.
04-16-2019, 09:35 PM | #129 |
I now have the needed puzzle pieces to start floor and body repair stuff. This will be a challenge for me.
04-17-2019, 12:07 AM | #130 |
Go slow, take pictures, ask questions, etc. Many have been down this road before and have made pretty good progress.
It can all be fixed. |
04-18-2019, 08:38 PM | #131 |
Thanks, your rust repair information will help me greatly.
7D2N
05-21-2019, 08:59 PM | #132 |
Just a little progress but no welding. I have trimmed and fitted, trimmed and fitted again, put the door on and then take the door off. This takes a lot of time. I plan to start welding soon.
05-23-2019, 11:39 AM | #133 |
Great work so far! Looks like you are making awesome progress.
05-24-2019, 07:10 AM | #134 |
I agree! if can make past the "B" post ,you've got it made. they're like like pcs. at that on intersection. I actually added one more for additional support I took the guts out of my door, it was getting to heavy, for the amount of times I took it off and on good luck on the welding
08-14-2019, 10:43 PM | #135 |
I started welding and grinding and not very good at either.
7D2N
08-14-2019, 11:00 PM | #136 |
still, lots to go.
7D2N
08-14-2019, 11:08 PM | #137 |
That is really starting to take shape, nice job.
08-15-2019, 06:00 AM | #138 |
Just don’t stop! Keep plugging away. Progress looks great.
Justin 1970 Blazer in progress |
08-15-2019, 08:38 AM | #139 |
Great job so far!
I'll be referring to this thread many times this winter as I start my project... Keep up the good work!
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
08-16-2019, 08:41 AM | #140 |
Thanks for the pic inside 'B' post, didn't cut mine open that far. worried something rusty was goin' to stare back at me. bottom of 'b' post is one of the most complex parts of the blazer
great work so far, thanks for posting up and entertaining me while mine sits in electrical prison
10-03-2019, 10:08 PM | #141 |
I'm working on the outer B panel patches and I have some questions if anyone has replaced these, should there be a flang or tab on the bottom panel to attach the panel to the end of the rocker box.
10-16-2019, 01:45 PM | #142 |
Here's a couple of pictures of how it should be. The b pillar area on this Blazer is original & unrestored . They are just a tab that is spot welded on.
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
10-16-2019, 09:33 PM | #143 |
Thank you for the response that will help me a lot. I had no reference of how it should have be attached since mine and had rusted away.
10-16-2019, 09:56 PM | #144 |
had no idea they were under there ty
You did an excellant (speling), job on the sheet metal work
11-30-2019, 07:33 PM | #145 |
Small update. I have the outer rockers and B pillar patches alined with the fenders and doors and ready to weld. My doors need work, do you think door patch panels or complete door skin?
01-16-2020, 09:24 PM | #146 |
I decided to repair my doors with lower skins and made some inside B Piller repairs. oh, make sure you have your door seals on before adjusting door gaps.
it will save time. I should have know that I read it here.
01-17-2020, 12:08 AM | #147 |
Looks great! Keep it going and you will be done in no time.
Pat |
01-28-2020, 09:23 PM | #148 |
The B pillars are welded in and the outer rockers are tacked for panel alinement. I did run into this problem after I got things alined, the top of both doors leaning out. I'm wondering about these welds, should I grind them off and reweld them in the right position?
01-28-2020, 09:33 PM | #149 |
The Exhaust manifold on the driver side I think is for a 2 WD ,4WD goes straight down.
Great Build |
01-29-2020, 10:15 PM | #150 | |
