#176 |
Re: Ridetech 4-Link Coil-Over Install
We can probably get you in a good spot just using a set of our HQ shocks with what you have. If you can get me a measurement from mount to mount at ride height in the front, I can spec something out for you.
John J. Sales/Tech Direct Line: 812-481-4737 Office: 812-482-2932 JJohnson@ridetech.com Instagram: @ridetech_john |
#177 | |
I do need front shocks... I'll measure when I get the motor in and back on the ground. Truck is getting painted next.
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
#178 | |
Do you offer same shipping and T deal for our other vehicles? We need the matching IFS to this c3 rear kit http://www.youtube.com/watch?v=DJZzc...ature=youtu.be My other car is also due for an upgrade... I need more money and time for all the stuff I'd like to do.
GIZZmotorsports on YouTube & my panel truck build '69 c10 panel, '75 c35 flatdeck car hauler |
#179 | |
#180 |
Is there anything you guys would like to see pictures of?
#181 | |
#182 | |
#183 |
Mine did not
#184 |
I ordered the front brace kit and mine didnt come with the heim joints so this must be a newer design
1964 Coupe Deville(cruiser) 1966 Chevy II Nova 2door Hardtop 1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys 2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s 2000 Trans Am WS6, LS1/T-56, too many mods to list |
#185 |
Like the look of the "squared" u bolt for the rear diff brackets on the 4 link....I might have to see about bit upgrade for mine.....would have to be way better then 4 bolts a side....
#186 |
John @ Ridetech, I would like to know, why on earth isn't there a rod end at both ends of the panhard rod? Even getting things lined up during install, I have to bind the bar into place. I can only imagine what it's doing going down the road, even with a heim joint on the passenger side. Ever have anyone cut off the urethane bushing on the driver's side and weld on a reverse threaded piece of tubing so they could run a 2nd heim joint? Even the Mustang guys do it:
#187 |
Is John @ Ridetech still monitoring this thread??
#188 |
Happy to be here
![]() Join Date: Mar 2000
He is, but he has been traveling quite a bit too.
#189 | |
Proud Vet that loves the USA
![]() Join Date: Jun 2016
I will most likely make all new bars with dual heim joints in the near future. And John has been on the road ALOT the last few weeks. Bubba |
#190 |
Whats up guys! Im terribly sorry for the slow response time.
I've been all over the place recently and for whatever reason, I stopped getting notifications on my new phone when someone replied to these threads. Anyways, you guys are correct. The new design does NOT include the parallel brace that runs between the two primary brackets. When we originally designed that brace, we believed that having the additional component in there would prove to be beneficial in stiffening the front end. Come to find out, the other bars did an adequate job of removing flex on there own so we removed the double heim end piece (which in turn helped reduce the over all retail cost.) As for the rear panhard bar, it has to have a fixed style bushing on one end. If not, the bar will rotate and you will have metal on metal contact which would create abnormal wear and excessive noise. That is the main reason for the bushing on one end and the R-Joint on the other. That design provides minimal stiction, noise and rotation. Hopefully that will help you guys out. As always, if you ever need anything dont hesitate to call me direct at the office. Ill be more than happy to try and answer any questions you have (812-481-4737). You can also shoot me a message direct on Instagram @Ridetech_John
#191 |
I will try and get some photos of our exhaust, hopefully that will help.
Ken (N2TRUX) has some pretty detailed photos of his exhaust. Maybe that will help you out.
#192 | |
#193 | |
I've got the 4-link installed on my truck right now. But I couldn't help notice that I had to pry the panhard bar into place. Binding at rest will be multiplied several fold as the suspension articulates. It just seems to be like a bad design considering you are already using one of the "R-Joint" heim type joints on the passenger side. Basically 100% of the solid rear axle panhard bar setups on the market today from BMR, Maximum Motorsports, and others use this dual heim joint swedged tube design. The added benefit of the swedged tube is that it allows you to center the rear axle with the truck/ car on the ground instead of removing the bar over and over to do so. Perhaps I'm beating a dead horse here and need to modify this new kit as I see fit. ![]() ![]() ![]()
#194 | |
Because the bar is bent, obviously the weight of the bar is offset. Because of this, if you put a double heim on the bar it would rotate down towards the ground. In a situation where the roads were bumpy or rough..the bar would "flop" up and down THEN we would be on here talking about why we didnt put a bushing in it to cut down on rotation. The panhard bars job is to keep the rear end housing located in the center of the truck. If you take it out, there is a chance that the frame and rear end would not be centered (especially when you remove all of the rear suspension to install a 4-link) So, its not uncommon that the panhard bar doesn't fall right back into place when you reinstall all of the suspension. Our engineering team has designed the bar to re-center the rear end in the truck, they did the math to ensure that the bar length is correct. We made one end adjustable for small adjustments where needed. If the amount of adjustment that is built into the R-Joint wont get the rear centered, then you may have something else going on. Hopefully this clarifies why we dont use double heim ends.
#195 | |
#196 | |
We put that bend in the bar to accommodate different housings.
#197 |
Happy to be here
Exactly. With out that bend a straight bar would be close to the rear end cover. For those that chose to run a HD rear end, or a high capacity cover this resolves those clearance concerns.
#198 |
Happy to be here
When I bought Scarlett it had dual exhaust that ran out behind the rear wheels. I really liked how the Borla XS mufflers sounded great outside, but the rear exits and a butt load of sound dampner made the cab nice and quiet. Running true duals out the back is a challenge with a 4 link, but it is possible. My guy was able to rout 2.25" exhaust pipes up and over the axle. He ran straight back and we added turn downs right before the rear bumper.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-18-2018 at 10:26 AM. |
#199 |
Hey John, what size wheel and tire are you using on this truck?
