Old 11-06-2018, 08:26 AM   #776
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
Awesome Thanks
reaper71 is offline   Reply With Quote
Old 11-06-2018, 07:52 PM   #777
reaper71
reaper71's Avatar
Pic 1. This is my scribe gauge I made a while ago.
Its fully adjustable
Pic 2. Make a perfect line set at the length you need.
Pic 3. Cutting the tube in half for a lower riser.
Pic 4-5 I'm using (My friend John's) porta-band from Harbor freight (Bauer) and have it mounted to a portable table from swag off road.
The saw is usually on sale $140 and the table goes for $125, This super useful for cutting tubes under the vehicle and with the table you can cut shapes pretty easy.
Mark
Old 11-06-2018, 08:02 PM   #778
joedoh
joedoh's Avatar
thats a neat setup! thanks for the tip, I have always wanted a small band saw setup and that is certainly not expensive.
Old 11-07-2018, 08:52 AM   #779
reaper71
reaper71's Avatar
Joedoh, It's a really handy unit to have.
Cuts through tubing like butter!
Old 11-07-2018, 10:42 AM   #780
mongocanfly
mongocanfly's Avatar
that is a nice bandsaw setup...luckily my horizontal saw will standup vertical....it just doesn't have abig table...but I could easily make one for it..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-07-2018, 12:07 PM   #781
8man
I have the Milwaukee saw (got used on Craigslist) and that Swag table. Yes, it will cut! Like Reaper said, it's nice.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 11-07-2018, 08:57 PM   #782
reaper71
reaper71's Avatar
You can't have to many tools right Guy's!!!
Mark
Old 11-07-2018, 09:15 PM   #783
reaper71
reaper71's Avatar
update:
Pic 1. This is why I was showing the saw, I cut it in half to make risers for the radiator. the radiator has a pocket on the bottom and these will fit inside of it and lock it in place.
Pic 2-3 I made these plates to tie in the upper fender to the radiator uprights.
Pic 4. Cut and welded in.
Pic 5. Starting to take shape.
Mark
Old 11-08-2018, 05:37 AM   #784
RockinKees
RockinKees's Avatar
Great tools, these bandsaw, my buddy has one too!
Great idea for the radiator!
Within a few day I have to build a radiator in the Mustnag II of my son, his alternatorbelt went through it...
You give me great ideas!! Thanks!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-08-2018, 08:33 AM   #785
99 to Life
99 to Life's Avatar
dude that saw set up is awesome. I like that is not a huge unit that is planted in my already tiny garages!!! Core support is looking good. I'm in the process of designing one myself. thanks for the tips!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-08-2018, 08:35 AM   #786
reaper71
reaper71's Avatar
Thanks Kees!
Good luck with the Mustang
Old 11-08-2018, 08:41 AM   #787
reaper71
reaper71's Avatar
Kees, speaking of Mustangs this is a customer's car I had done suspension,rear end etc. On a few years ago.
He had some fender damage that needed fixing, anyways I talked him into respraying the car in matte clear.
Mark
Old 11-08-2018, 08:46 AM   #788
reaper71
reaper71's Avatar
Thanks 99!
It beats having to cut everything with a cutoff wheel (and the stink of said wheel) by a mile!! and it takes up minimal space.
I've seen some guys making a stand for these that can be moved around the shop.
Mark
Old 11-11-2018, 10:00 AM   #789
reaper71
reaper71's Avatar
Pic 1. Radiator set in place, now I can make a upper mount.
Pic 2. I didnt take shots during this step.
The 2 bolts closest to the radiator come out and the upper mount lifts a bit and slides out.
Pic 3. a closer look of the passenger side where it's slotted to slide around the filler neck.
Pic 4. Now I can move on to the radiator splash apron, I had one but it was so tore up I cant use it. So i will need to find a new one.
Mark
Old 11-11-2018, 10:29 AM   #790
RockinKees
RockinKees's Avatar
That’s some nice enigering Mark!
Good looking Mustang too!
My son has a Mustang II, the car nobody wants....but it is a really nice driver!
Cheers!! Kees.
Kool Guyz CC
Old 11-12-2018, 08:47 AM   #791
reaper71
reaper71's Avatar
Thanks Kees
My best friend had one in High School, thought it was a racecar!
Nice work shed btw
Mark
Old 11-16-2018, 09:22 AM   #792
reaper71
reaper71's Avatar
Not much of an update, but here is a few shots of the truck with the hood back on.
I needed to put the hood on to check fitment of the hood to fender placement. I will need to make some adjustments with the core support I made to help with the fender support.
Mark
Old 11-16-2018, 10:16 AM   #793
8man
You do some nice metal work!
8man-aka Robert
Old 11-16-2018, 11:06 AM   #794
99 to Life
99 to Life's Avatar
killer
Old 11-16-2018, 12:48 PM   #795
joedoh
joedoh's Avatar
looks outstanding, really really nice work.
I am waiting on a DAR determination this morning, leafing through the AD FSM with my coffee looking at how to adjust the hood, I moved my hinge and that didnt really help anything.
Old 11-16-2018, 01:33 PM   #796
RockinKees
RockinKees's Avatar
Really like the front this way!
Wish those LS engines were so easily available overhere....
Cheers!! Kees.
Kool Guyz CC
Old 11-16-2018, 08:17 PM   #797
reaper71
reaper71's Avatar
Thank You Guys...very Kind!!
Old 11-16-2018, 08:18 PM   #798
reaper71
reaper71's Avatar
Kees, We could always check on the shipping and get one on the way!!
Old 11-18-2018, 05:00 AM   #799
RockinKees
RockinKees's Avatar
That would be awesome Mark!!
But first have to do some fundraising then....
Cheers!! Kees.
Kool Guyz CC
Old 11-18-2018, 09:52 AM   #800
reaper71
reaper71's Avatar
HaHa I feel your pain!
