11-06-2018, 11:27 PM | #51 |
Re: What did you do to your truck today.The 3rd chapter
It was yesterday , but I drove to Rocky Mountain Forest Products and picked up my special ordered 1"x8"x8' beetle kill pine. It came in to the yard in 5 16' boards and so they cut them down to 10 8'ers so I could haul'em home.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-06-2018, 11:37 PM | #52 |
Who Changed This?
The beetle kill pine has some interesting colors and holes from the bugs, but for my money the beetles oughta be killed outright.
11-07-2018, 12:32 AM | #53 |
I copied member OregonNed and replaced the battery terminals that the resto shop from Hell had ruined when I got my truck out of jail
Their shoddy work has me checking off a long list of items to correct, repair, and replace. All is good now...moving on and feeling better that I am fixing things myself. |
11-07-2018, 06:26 AM | #54 |
Took apart the Rochester 2 barrel so it can take a bubble bath then get rebuilt.
1970 C10 CST, PS, PB, AC, patina, original, work in progress |
11-07-2018, 08:44 AM | #55 | |
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
11-07-2018, 04:26 PM | #56 |
i realigned my driver side door on my 71 C-10. results are pleasing and the door closes 80% better but i'm still getting a draft in the upper portion so i think it's time to replace the weather strip
11-07-2018, 04:48 PM | #57 |
Hi, i replaced the original Delco starter with a GM mini starter from DB Electrical a week or so ago. It crapped out after 5 days. I contacted DB and they replaced it right away. Sounds great now, hope I get more than 5 starts. DB’s service is first class, no tech assistance tho.
Tom
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors |
11-07-2018, 05:01 PM | #58 |
New antenna installed.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
11-07-2018, 05:10 PM | #59 |
New rotors, 2.5" drop spindles, lowering shocks, lowering springs, brake pads and new ball joints.
11-08-2018, 01:41 PM | #60 |
Finaly freed up some time to work on the new motor for the 67
Crank and pistons installed now back in the bag till next time |
11-08-2018, 02:50 PM | #61 |
Played with a cnc plasma cutter today that a friend just bought. Made a plate to install a stock radio in my truck. Used a piece of scrap stainless
11-08-2018, 11:53 PM | #62 |
Some progress and learning a lot. I'm slow on things first time out, but I did manage to get this done over the last few days. Nice when you have the parts. 4" drop.
Ask me about torque on leaf spring suspension.......I can give you a lengthy unspecific answer, but close Go figure, you can buy replacement saddles and plates after all. Can't speak for their quality, mine were still good.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-09-2018, 12:38 AM | #63 | |
How do you plan to attach it to your cut radio opening? My dash was also unfortunately cut for a newer stereo by the previous owner. That plate, color matched hugger orange and I would be good to go! I think there would be a lot of interest from people with cut original dashes....just saying Good job. Sam |
11-09-2018, 07:42 AM | #64 |
It must be frame / suspension assembly week ?
4" drop springs all new brakes ,lines ,cables cross member cut/tubed for tucked exhaust with new trailing arm bushings Complete new front suspension cross member /all new Moog parts with drop spindles and springs , disc / power steering conversion ,factory front sway bar 9/16 U bolt upgrade ,all new grade 8 hardware . My 350 is ready to drop back in again . I'll be building a set of these rear shock re locators today to see how they work out . http://67-72chevytrucks.com/vboard/s...d.php?t=763851
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 11-09-2018 at 09:28 AM. |
11-09-2018, 09:08 AM | #65 |
It's actually suspension disassembly week for me. Removed both front spindles for disc conversion and tore both ball joint boots on the right side, then discovered that the upper cross shaft bushings were worn, so next up is removing the upper control arms and replacing the bushings. Yay!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-09-2018, 09:24 AM | #66 | |
11-09-2018, 09:34 AM | #67 | |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-09-2018, 11:43 AM | #68 |
Getting it ready for autorama in a couple of weeks
11-09-2018, 04:19 PM | #69 | |
11-09-2018, 04:44 PM | #70 |
For me it was carb-disassembly-week. Blew it apart and started the cleaning, rebuild process. Replacement parts arrived today, so tomorrow will be to reassemble carb, attach new choke components, install and test.
11-09-2018, 04:55 PM | #71 |
I stained my truck bed few days ago, its wood that came off a tear down barn so it was a real dull grey weathered color, so I thought i would make it a bit less dull and protect it as well as I really like the real old barn wood.
1969 'Matte Blackie' Oshawa Built Chevy C10 Stepside 307 three-on-the-tree |
11-09-2018, 06:58 PM | #72 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-09-2018 at 07:04 PM. |
11-09-2018, 08:33 PM | #73 |
The original front cross member had some pitting on the upper control arm plate and I have a long bed parts truck that was much cleaner ,So I pulled the front member complete off the parts truck and stripped it down and bought all new parts to rebuild it . Upper and lower Moog control arm shaft kits , upper and lower Moog ball joints , inner and outer Moog tie rod ends / connectors, Moog pitman arm for power steering and Moog idler arm . Rock auto had the best price on all of it at one time and done . I thought about just replacing the shaft boots but it's apart and it was only a few hundred more to replace it all .
11-09-2018, 09:54 PM | #74 | |
11-10-2018, 12:25 AM | #75 |
Got the bed back together, had the bed on kinda lose when I realized there is no way to get to the back bolt unless I drop the fuel tank. With the bed on theres no way to get to the nuts when placing the fuel tank. Welded the nuts in place, then got the bed where I want it and tightened down, then was able to put the tank back on. Always a learning experience.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
