Old 11-07-2018, 12:58 AM   #1
buildingmy68
alternator bracket combinations
Hello everyone
New here to the sight. I have a 68 3/4 ton . lowering and rebuilding. I am have some frustration with figuring out after adding power steering how to line up pulleys or the combinations to use?? Is it just trial and error? I did buy a long water pump as I was told it gives me some better alternatives for the brackets. I did pick up a passenger side bracket from a 73-87 models. Any suggestions??
buildingmy68 is offline   Reply With Quote
Old 11-07-2018, 09:26 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: alternator bracket combinations
A lot of of us have been through this and yes, it's trial and error unless you can find an engine that has not been scavenged and take all the parts needed.
I bought an old un-scavanged junk engine for about $150 just for the parts. I took everything in front of the block; alternator, power steering pump, water pump fan pulleys, fan and even the harmonic balancer and pulleys.
If the above is not possible and you're not worried about it not looking stock, then the internet vendors have a lot of different options.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-08-2018, 12:35 AM   #3
buildingmy68
thanks will experiment from the buckets of parts that the truck came with. The motor is from a 69 Camaro. Adding the power steering was easy.
