#2976 |
Re: PO has me PO'd
OK EPIC fail, plan B
went down to wires before it would pass thru grommet ![]()
#2977 |
![]() Join Date: Nov 2007
Re: PO has me PO'd
That rubber inside the grommet will stretch. It's a bear, but it will. I have two of those on the truck, one for the FAST wiring and another for misc stuff. The second one has over an inch of wiring thru it, wrapped in braided sleeve. Getting the 4L80 harness and plug thru it was a nightmare...until I got creative.
Here's what I did.... I took a transmission funnel (lubed with lithium grease) and gradually ran it thru the grommet to open it up. Think speculum. Then cut the end of the funnel off and passed everything thru. Pulled the funnel back out and cut it off the harness. |
#2978 | |
Re: PO has me PO'd
Waiting for my 1 1/2" sheathing to come in from( F-6) Wire Care, then I can put it all back together, and start to make my connections Thanks for the help
#2979 |
Re: PO has me PO'd
![]() With my skills of rod tying and fly tying, I may have found a way to keep the skrunky sound out my shielding, wraping thread around it seems to keep it aligned, we'll see as I keep working on it ![]() It seems that If you twist the shielding, it will allow it to lay better...follow the white tracer
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-16-2018 at 12:22 AM. |
#2980 |
Re: PO has me PO'd
![]() JMHO< but seems the rubber strecky tape wins out over the pure vynil
#2981 |
Re: PO has me PO'd
Epic fail, part #2, 1A
still scrunky, used 3/4" wire care and it slips under corrugated , with bushing taped in. Marked with paint stick to keep it aligned. Now has support
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-25-2018 at 08:22 PM. |
#2982 |
Re: PO has me PO'd
#2983 |
Re: PO has me PO'd
#2984 |
Re: PO has me PO'd
This is the saw that I will be using to cut the hole in the firewall. I've turned the RPM down as low as I can get it. I like the grit better, as it doesn't seem to bite in as muchas a saw blade
#2985 |
Re: PO has me PO'd
Large hole in firewall, cutting tool turned up a larger than expected burrr. Thought I was using a flow drill, 1/2 hour with a large file cleaned it up. now on to the wire harness
[url=https://flic.kr/p/2dmZGJT] ![]() Afternoon spent in the Camaro, brunch with wifey and toy shop for Grand children
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-04-2018 at 08:40 PM. |
#2986 |
![]() Join Date: Jan 2007
Re: PO has me PO'd
You have way more patience that I do Jim! Looking good.
#2987 |
Re: PO has me PO'd
Thanks Bud, but what else would I do with my retirement. I bought all my tools to do this, over the last 40 years.
I just wish I knew what I was doing, so I could explain it to the forum. Harness is now thru the firewall, just have to shorten wires to make it fit ![]()
#2988 |
![]() Join Date: Mar 2011
Re: PO has me PO'd
that cleaned up real nice Jim whats it lok like on the engine side ?
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#2989 | |
Re: PO has me PO'd
I guess you could say that was a test fit.... probably pull runner, to gain access My head hurts just thinking about it. ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-08-2018 at 12:23 PM. |
#2990 |
Re: PO has me PO'd
Zicc, thanks for the interest, but I may get my oil pan back up first, since the oil has drained out of the engine, I want to prime it back up thru the new oil filter and lines I installed, see what the gauge reads, and then rotate crank shaft, it seems a bit solid. Maybe put something down the bores
any work on your project or are you still traveling alot?
#2991 | |
Re: PO has me PO'd
![]() thanks Merry Christmas Jess
#2992 |
Re: PO has me PO'd
I gotta say I miss the fires I used to put out for the companies I worked for over the years(sometimes) then I work on my truck and forget it. But, I do miss the money
Maybe we can get together over the holidays, bring wifey want to buy a bore scope, see what's going on in the chambers
#2993 |
Re: PO has me PO'd
Alittle over-exhubriant....
wires are to long, should breake out closer to fuel regulator ![]()
#2994 |
Re: PO has me PO'd
Needed more room to work, had to pry up( about 1/4" ) fuel rails, left bolts attached, to get runners off, also v/c's
![]() Now to bring wires out at coil connectors
#2995 |
Re: PO has me PO'd
This bolt has to come out to raise, do not pry on fuel rail cross tubes
#2996 |
Re: PO has me PO'd
Also, trying to reconfigure shifter boot, from square body turned upside down. Will have to section the aluminum ring
#2997 |
Re: PO has me PO'd
Note to self,DON'T use duct tape in harness...gluey mess... goo be gone
#2998 |
Re: PO has me PO'd
#2999 |
Re: PO has me PO'd
Thanks for the tip, I'll keep in mind as I go further into the harness
#3000 |
Re: PO has me PO'd
Since I relocated my trans shifter to a trans mount I opened up a hole for the twin e-brakes, single rear wheel each. Stock console should go back to the oem location
![]() secret santa gave me a trans temp unit, waiting on mount bowl from auto meter
