Old 11-10-2018, 08:21 PM   #76
FL71C10
Re: What did you do to your truck today.The 3rd chapter
Got my new electric fans and shroud assembled and screwed to my radiator.
Little by little....
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 11-10-2018, 08:27 PM   #77
kcmarkd
kcmarkd's Avatar
Today was fun filled!
Carburetor - reinstalled the newly rebuilt carb, with new brass float, missing choke pull off, new idle mixture screws, and new jets. Once warmed up, adjusted idle mix, timing, and initial adjustment of choke. Waiting until it is dead cold to tweak choke pull off. Supposed to be a low of 24 tonight, so dead cold is right about now.
Heater - dissected the heater box in the cab and found several interesting things. First, the outlet flap was broken and just flapping about. So, given it is winter here, just removed it all together. Will address the remainder next spring. Second, determined why my air flow was non-existent, and removed the remnants of a prior tenant. It looked rather cozy, if you were a mouse. I took a picture, but didn’t include it here. Ain’t nobody wanna see that...
Installed parts from GMCPauls: wiper arms and blades, and new gas cap.
Finally, replaced the driver door lock so the key matches the passenger door lock.
1970 C10 CST, PS, PB, AC, patina, original, work in progress
kcmarkd is offline   Reply With Quote
Old 11-10-2018, 08:40 PM   #78
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
Finally got the tires mounted on the new to me front chrome wheels and installed on the ramp truck.
I think I need some center caps.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-11-2018, 12:51 PM   #79
66clow
66clow's Avatar
Block party with one Attendee 😩 also roof rail clean up.
66clow is offline   Reply With Quote
Old 11-11-2018, 12:55 PM   #80
Speedracer39
Speedracer39's Avatar
I was wondering what brand of fans did you buy and how is the fit?
Speedracer39 is offline   Reply With Quote
Old 11-11-2018, 08:04 PM   #81
FL71C10
I bought the fans and the Shroud separately. My friend actually gave me the fans, they are 14 in cheap generic fans. I got the Shroud from ledfoot racing. It's designed to go on a replacement Champion radiator but it fit very nicely on my four row original radiator.
Old 11-11-2018, 08:42 PM   #82
samkost
samkost's Avatar
I got a few things done.
Radiator overflow installed/plumbed.
Some new firewall grommets.
Cleaned up my small garage, tools and work bench.
Next on the to do list, wiper washer hoses.
Time for dinner and a brew
samkost is offline   Reply With Quote
Old 11-11-2018, 09:01 PM   #83
Jim70Chevy
Jim70Chevy's Avatar
This weekend I tackled the drip guard. I started by removing the old seam sealer. I used a chisel for much of it and then based on a tip from this board I finished it with a wire wheel. I then treated the whole channel with a couple coats of por15 and let it dry overnight. Next day I used the self leveling seam sealer and after letting that dry for several hours (the label says you need 30 minutes) I gave it a coat of TCP 2k epoxy primer using the preval sprayer.
"Every professional was once an amateur who didn't give up"
My build 1970 Longbed CST/10
Jim70Chevy is offline   Reply With Quote
Old 11-11-2018, 09:33 PM   #84
nlped
nlped's Avatar
Didn’t get any of the parts I’ve waiting on to move forward in Walter so I started on the install of the CVF serpentine pulley setup (bought it at SEMA show) and Sanden 508 a/c install on my ‘77 square.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-14-2018, 06:23 PM   #85
kcmarkd
kcmarkd's Avatar
Replaced the alternator and re-did the shattered connector plug. While I was at it, I saw that the fuel pump was squirting gas from the weep holes in the top of the mechanical pump. So, got a new pump and will be doing that next.
Old 11-14-2018, 07:51 PM   #86
Steeveedee
Who Changed This?
Steeveedee's Avatar
Smell your oil for fuel. When the diaphragm goes, the pump can leak fuel into the oil.
~Steven
Simi Valley, CA
Old 11-14-2018, 08:58 PM   #87
332rick
332rick's Avatar
Working on my brakes - replacing everything but the drum.
332rick is offline   Reply With Quote
Old 11-14-2018, 09:12 PM   #88
kcmarkd
kcmarkd's Avatar
Good to know. It is time for an oil change anyway, so will take care of that after I replace the pump. Thanks!
Old 11-14-2018, 11:04 PM   #89
PepperTreeGarage
PepperTreeGarage's Avatar
Finished the C-Notch and helper bag mount with extra inner and outer plates on the C20.
PepperTreeGarage is offline   Reply With Quote
Old 11-15-2018, 06:33 PM   #90
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Freshened up a gauge cluster for the 67 Vermillion/white CST. Going to go from this broken bezel.....
To this.
Special thanks to TBONE1964 for the calibrate and paint on the speedo and TOO MUCH STUFF for the choke delete & throttle place card.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 11-19-2018, 07:35 AM   #91
kcmarkd
kcmarkd's Avatar
Installed cowl vent trash guards, and replaced the cowl fresh air flap. Removed failed fuel pump, only to find that the parts store sold me the wrong one. So, will be getting the right pump today, then reinstall later tonight.
In the mean time, spent some time working to understand the AC vacuum routing/functionality and replaced a few of the 50 year old vacuum lines under the dash.
Old 11-19-2018, 09:43 AM   #92
72LB
72LB's Avatar
Working on a disc brake upgrade and rearend swap.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 11-19-2018, 10:19 AM   #93
Triple7
Having a new windshield installed
Triple7 is offline   Reply With Quote
Old 11-19-2018, 06:14 PM   #94
NoStopN
NoStopN's Avatar
Yesterday, I finally slid the tail lights into my bed. I'm just glad that the wiring worked as it should.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 11-19-2018, 08:46 PM   #95
samkost
samkost's Avatar
Finished the 72's rear trim this weekend.
Taillights, upper/lower tailgate trim and a new sport bumper.
The taillight bezels were fun........not!
A shout out to forum members:
Wes, Classic Heartbeat
Mark, CG
Leon, LockDoc
Thanks for your help and advice gentlemen
Sam
Old 11-20-2018, 05:33 PM   #96
Grumpy old man
Grumpy old man's Avatar
New Moog control arm shafts . Just waiting on more parts ...As Always ..
Old 11-20-2018, 05:40 PM   #97
70STOVEBOLT
70STOVEBOLT's Avatar
Got one upper control arm ready to install. Went with Dorman shaft kits and GM NOS upper ball joint. Blasting the other one tonight and getting it assembled and painted hopefully by tomorrow.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-20-2018, 06:04 PM   #98
Grumpy old man
Everything on this truck is being restored /repaired or replaced and it will be sold once it's finished and I'll go on to the next one .
Old 11-20-2018, 06:06 PM   #99
Grumpy old man
front to back .
Old 11-20-2018, 06:20 PM   #100
samkost
samkost's Avatar
Very nice work Grumpy,
Do you have a build thread?
I'm curious what year, model and color(s) truck you are restoring.
Thanks,
Sam
