Old 11-11-2018, 08:36 PM   #1
Jeff's72C10*
Active Member
Jeff's72C10*'s Avatar
Need some frame expert help
I think I posted a pic of the damage of the front frame cross member on a truck I purchased a while back. I have a friend who has an early 80's frame that the cross member is in excellent condition. He says the frames are the same from 67 to the early 80's as far as the front section is. Can anyone verify that this would work on my 72? Appreciate any help. Photo of my damaged one for reference. Thanks again
Previous C10's
69 SB CST - sold
72 Cheyenne Super LB - sold
Jeff's72C10* is offline   Reply With Quote
Old 11-11-2018, 08:45 PM   #2
notsolo
notsolo's Avatar
Re: Need some frame expert help
You may opt for swapping out the whole front cross member, axle hub to hub, cross members fit thru "87"...That's what's under my "72" works fine.
notsolo is offline   Reply With Quote
Old 11-11-2018, 09:45 PM   #3
Jeff's72C10*
Active Member
Thank you, appreciate the info. He's giving me the whole frame. I can't use it except for parts as it's a shortbed frame and I have a long bed. It does have a 12 bolt posi rear end, disc brakes on the front and a set of the rallye wheels, so that's a plus. I'll probably swap the whole thing, but replace the bushings and such first.
I would imagine to swap the front cross member the engine will either need to come out or some way be supported? Thx again
Previous C10's
69 SB CST - sold
Old 11-11-2018, 10:02 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Be easier with the engine out.
Could also use the clamshell style motor mounts as well.
Old 11-11-2018, 11:40 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I just jacked my engine up and blocked it while I swapped the entire cross member on one of my trucks. I had to re-drill one hole on each side and enlarge one hole on each side. I think the front cross member is the only assembly that will swap in with a minimum of modifications.
LockDoc
Leon
Old 11-11-2018, 11:42 PM   #6
Jeff's72C10*
Active Member
LockDoc
Thank you sir for the additional info. Appreciate it.
Previous C10's
69 SB CST - sold
