Old 11-21-2018, 01:42 PM   #1
manimal
manimal's Avatar
4x4 frames...k10 vs k20
Ok, before people starting posting.."SEARCH", I have, nothing definitive has been posted, no actual information.
So my question is, for those who have a STANDARD CAB LONGBED K20 4wd, can anyone measure the thickness of the frame rails for me. I have a K10 LWB frame, I have gone on GM Heritage and read the info there, but then I have seen postings of frame thicknesses before and none of that info matches. I am wanting to build a K20 out of it, but I want REAL LIFE measurements to match my frame to.
Thank you.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 11-21-2018, 02:19 PM   #2
andyh1956
Re: 4x4 frames...k10 vs k20
All I have is an 84 K30 Camper Special, the rest are K10s.
I know the frame is taller on that 30 but I will measure thickness for you if you think it will help you.
andyh1956 is offline   Reply With Quote
Old 11-21-2018, 02:32 PM   #3
D13
D13's Avatar
1977 Heritage Center shows K10 LWB and K20 LWB both have 3.92 frame modulus, so the frames are the same.
As far as actual measurements, you would need a clean unrusted unpainted frame and then measure each individual section shape.
i can tell you here in Michigan 100% thinning is common. Like, missing from salt corrosion LOL.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-21-2018, 10:31 PM   #4
SunSoaked
SunSoaked's Avatar
I've been wondering for some time what the "Heavy Duty Frame" on my 85 K20 means. That's what it says on the SPID. Was there a "regular or light" duty frame?
SunSoaked is offline   Reply With Quote
Old 11-21-2018, 11:27 PM   #5
dmack91
dmack91's Avatar
I have an 83 K20 and just forward of the rear cross brace, the frame measures 4 3/4" tall, 3 1/4" wide, and 3/16" thick. Best I can do with a tape measure in the dark. If you need something else or more precise measurements, let me know.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-22-2018, 01:27 AM   #6
manimal
manimal's Avatar
Awesome, THANK YOU to all of you.
-Lance
Old 11-26-2018, 07:24 AM   #7
D13
D13's Avatar
Yes, there is a 'heavy' duty 3/4 ton frame available. Weight was taken out of the frames in the 1981 redesign, but there was still an need for a stronger frame for certain applications. Usually goes along with HD suspension, most common on the military pickups and firefighting units that we always heavily loaded.
1987 2 ton
Old 11-26-2018, 01:10 PM   #8
sweetk30
sweetk30's Avatar
military pickups were k30 1tons . totaly different frame size . and most fire truck ambulances were build on these frames also . i have seen some k20 fire trucks but not a lot .
2 easy ways to spot a k30 only frame is the middle section of the frame like under the cab is 8.25" tall almost 2" more than 1/2 and 3/4 ton frames . and in the rear 1ton frames had inboard shocks on a set of 4 bolt riveted in frame ear studs . this was cause the outboard shock design of 1/2 and 3/4 ton would not clear the leaf springs being sucked in 1" each side to make room for the narrow c&c axle option if it was to be a drw c&c truck .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-26-2018, 01:30 PM   #9
SunSoaked
SunSoaked's Avatar
I found my rpo code (C6P) actually states HD Chassis so it may have nothing to do with the frame, rather the springs? Swapping in the 14ff & Dana 60 probably only lowered my payload capacity. Lol. Of course I probably gained it back when I swapped to the Vintage Air system and lost 300 lbs of useless wires, vacuum hoses, cables and connectors.
Old 11-26-2018, 09:57 PM   #10
Caminuvik
Would this be applicable to earlier years? I have the shocks inrail, yet the rails under the cab look to be more closer to 6" tall (I will check more carefully.) It does have a full floater rear end. Not sure at all of the original configuration of the truck. Thanks
Caminuvik is offline   Reply With Quote
Old 11-27-2018, 09:49 AM   #11
MJN
MJN's Avatar
I could be mistaken but the pre-CUCV (1976ish era) Canadian military pickups were K20's with Dana 44 front axles and would explain the 6" frame rails vs the later K30 trucks (not in production until 1978) and CUCV's that used the 1-ton frame with 8" rails. Both would have the full float rear axle. Some more research would have to be done to determine if the Canadian trucks were equipped with heavier rear springs and used the inboard shocks the 1-ton's used.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 11-28-2018, 11:52 PM   #12
manimal
manimal's Avatar
If someone that has a K20 would actually measure thickness with calipers or micrometer, I can do the same for the K10, and someone with a K20 CAMPER SPECIAL could do the same thing, we can FINALLY put this to rest. I will take measurement in 3 locations, right in front of engine crossmember, under cab and around area of tow hitch. I will clean these spots well and post my findings.
-Lance
Old 12-01-2018, 12:06 AM   #13
dmack91
dmack91's Avatar
I mic'd my K20 in three spots and they ranged from .225 to .255.
