Old 11-26-2018, 11:50 AM   #1
justaburbn
81 GMC K30 Transfer Case and locking hubs
The transfer case and hubs seem to be stuck. I can not get the transfer case out of 4H and the locking hubs will not turn freely. They were both working fine when I bought the rig. I have only owned this truck for 2wks now and I am not familiar with anything yet.
Any help getting familiar with this issue would be great. I think it is an NP205?
justaburbn is offline   Reply With Quote
Old 11-26-2018, 12:55 PM   #2
sweetk30
sweetk30's Avatar
Re: 81 GMC K35 Transfer Case and locking hubs
unless someone swapped it k30 in 81 will be a np205 .
if your in 4wd and on pavement it can be tricky to get them out . do the t-case first . then the hubs . also try undoing this stuff on grass or gravel it can help the bound up problem . and wheels stright .
its also a good idea to get some spray oil and lube the linkage under the truck for the 4x4 shifter . the pivot bolt might even have a grease zerk .
stock single lever np205 shifters have always been a bit cranky . i swapped to a aftermarket twin stick years ago and it shifts WAY better . i will never go back to a single lever again . i got mine from offroad design .
for spray oil i like napa 1370 chain and cable lube . goes on thick foamy and turns sticky oil to stay in place and takes months to dry out .
and nice k30 truck and boss v-plow . she will be a tank for you .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-26-2018, 12:58 PM   #3
MJN
MJN's Avatar
If it has lockouts there is a good chance it's a NP205, however without seeing the shifter or transfer case this is only a guess since you can convert NP203 to part-time as well.
My guess is things are bound up and won't unlock (if nothing is broken). Put the trans in neutral on a level surface and you should be able to get the transfer case out of 4-hi. Usually rocking the truck back and forth by hand will relieve the tension on the drivetrain and you can unlock the hubs then too. I have this same issue with my '74, just have to rock it back and forth a little and then you'll be able to unlock the hubs again.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 11-26-2018, 03:14 PM   #4
SunSoaked
SunSoaked's Avatar
Not much help here but she's probably beyond repair. Your best bet is to sell it to me and I will gladly come pick her up.
Btw, curious about what's on the hood?
SunSoaked is offline   Reply With Quote
Old 11-26-2018, 04:10 PM   #5
1968k20
1968k20's Avatar
Back her up and it should pop out of gear
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 11-26-2018, 10:07 PM   #6
justaburbn
Changed the gear oil and took apart the Hubs (Spicer Hubs) cleaned the gunk out of them, lightly greased and reassembled today. Drove around a little bit, parked on level gravel and everything seems to be working fine. I will have to go back and look for a zerk and lube linkage.
Thanks for the tips.
Old 11-26-2018, 10:31 PM   #7
sweetk30
sweetk30's Avatar
no problem .
and KEEP them spicer hubs . there BEFFY as he!! . and if they ever did fail they fail locked unlike warn hubs and some other brands .
Old 11-26-2018, 11:07 PM   #8
justaburbn
It definitely is NP205.
Old 11-26-2018, 11:11 PM   #9
justaburbn
I should at least drop more money into it than it is worth first though, don't you think?
It was originally a firehouse rig. That is the no. 81 on the hood.
Old 11-26-2018, 11:14 PM   #10
justaburbn
That's what I thought when I had them apart but it just didn't register completely. Good to know. Thanks.
Old 11-27-2018, 06:52 AM   #11
GM72K10
Next!
GM72K10's Avatar
Nice rig.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 11-27-2018, 12:04 PM   #12
hatzie
Moderator
hatzie's Avatar
Originally Posted by sweetk30 View Post
no problem .
You beat me to it. KEEP your Spicer hubs. They're tough as hell. Nothing like em is made anymore. Just keep em clean and lubed.
If the plastic centre breaks all is not lost. There's a writeup on how to fix it with Polyvinylchloride pipe and Epoxy
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-27-2018, 12:20 PM   #13
justaburbn
Thanks for checking in on this. I appreciate the conformation. I never even heard of Spicer Hubs before.
Old 11-27-2018, 12:23 PM   #14
justaburbn
Can you tell me a little more about what an aftermarket twin stick is please? Thanks very much.
Old 11-27-2018, 01:20 PM   #15
SunSoaked
SunSoaked's Avatar
These are twin sticks: separates the front/rear so you can use them independently. My 4500/205 combo.
Old 11-27-2018, 02:00 PM   #16
sweetk30
sweetk30's Avatar
note true . yukon hubs they took the best of the dana 44 style and dana 60 style and combined them and made them better . plus they stick out even less . https://www.yukongear.com/productdet...x?ProdID=11865
next there is this guy who makes new billiet aluminum dials a pair for 100 bucks . https://www.tdsideas.com/store/p6/Da...kout_Knob.html and all sorts of other kool parts .
Old 11-27-2018, 02:05 PM   #17
sweetk30
sweetk30's Avatar
yep stock np205 links both rails to give functions . separate them you get rear high/N/low and front high/n/low . you still can NOT mix ranges the like high & low not going to happen .
but if you also mod the shift rail or get a new rail if yours is worn bad then you can go and do front wheel drive option with the twin stick . this is more for offroad trails and such .
here is the link to ord web site page for there kit . its a basic bolt in kit in a hr or 2 for the average wench turning truck guy . http://offroaddesign.com/catalog/NP2...ckShifters.htm
i twin sticked my plow truck years ago and loved it . way better shifting and feel .
bonus if you do trailer is backing up in 2WD LOW range option with just the twin stick lever kit . yes this can be done stock single lever also if hubs are unlocked .
if you wish to get real crazy i did 6 levers in my 1 project thats not done yet . and the trans has a bell crank linkage to work correctly with it set so far up on the trans . fits threw a stock 4 speed shifter hole with 4 speed boot .
1= lokar auto trans / 2-6= winch in/out / hydro pto pump on/off / range box high/n/low / 205 rear high/n/low 205 front high/n/low
Old 11-27-2018, 07:42 PM   #18
hatzie
Moderator
hatzie's Avatar
Those are fairly recent replacement parts because this generation truck is gaining popularity.
Once you have the CNC program for milling the knobs it's not much of a leap to build a program for a negative of the knobs to make Injection molds for ABS or HDPE knobs.
The reason I'd stick with plastic, if possible, is Aluminum has a nasty habit of corroding when it's in contact with Iron or other metals. The plastic knobs have lasted 30+ years. Not so with the Aluminum knobs on my long gone 1969 IH Scout 800A or my 67 Dodge pickup in the barn.
Old 12-01-2018, 01:04 PM   #19
justaburbn
I just checked out offroad design. Oh my my! What am I getting myself into? This is going to become another expensive hobby. I think I'm going to have to trade in some old hobbies for this one. I thought I knew something about offroading....not!
SunSoaked, I'm not exactly sure what a 4500/205 combo is yet, but I'm guessing I might like to have one of those. I have some other rigs like a 79' Suburban that has a 400cid/Th400/203 I was wanting to make into a back road bush truck, but now I'm thinking GM Crew Cab short bed rather than a Suburban body (I have 4 young boys that don't drive yet) because if I was to put all these things together (with like a 203/205 doubler) and go where I want to go, I'm guessing the frame is going to twist a little.
For now I just need to concentrate on a drivable/bulletproof plow truck.
Do I ask about other issues on this thread or create a knew one? or a search?
I need a good old Rochester Quadrajet builder, not a reman piece of junk. Any help/advice here would be great.
I also think I'm going to have to figure out a way to make more money. Legally of course.
My apologies to all respondents. I am new to forums in general and have never engaged with anyone and still learning how to correspond properly. So to everyone, Thank You! and keep it coming. I'm just getting started.
Old 12-01-2018, 01:31 PM   #20
justaburbn
Sorry Sweetk30, just noticed your post. You guys are killing me! I getting goose bumps thinking about all the fun I'm going to have with my boys and hives at the same time thinking about all the info/research I'm going to have to digest. Love this stuff!
All I can say is thank you for all for the informative posts. I figured this was a good forum but I truly just took a blind leap of faith hoping not to get engaged with a bunch idiots. I am pleased to say this Forum and you folks are awesome!
Now I have to make time to try and to comprehend everything. I will do my best to keep up.
This 81' is an amazing old rig. However I'm still working on little things too, like wiper motor switch, bad plow connections, heater controls, slow electric window motors, carburetor (this one is the most painful), power steering pump/hydro boots etc...you guys know the stuff.
My main concern and interest is the drive/power train so thanks again!
