Old 11-26-2018, 07:40 PM   #1
MacQuigley
Headlight Switch
So, I now have 3 brand new headlight switches and 2 actuators and I cant get either actuator to lock into any of the switches. What the hell am I doing wrong - HELP, PLEASE!
MacQuigley is offline   Reply With Quote
Old 11-27-2018, 07:16 AM   #2
PGSigns
PGSigns's Avatar
Re: Headlight Switch
Sometimes I have had to push the button on the side that releases the knob to get them back in.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-27-2018, 09:50 AM   #3
MacQuigley
Tried that Jimmy but they just keep coming out.
It has to be something Im doing wrong, it cant be that Ive got 3 faulty switches, but what? Its not like its rocket science here, stick it in and it clicks in place.
Old 11-27-2018, 02:38 PM   #4
61K10
61K10's Avatar
there was a switch change in 64 or later? The rods are different lengths. The early one is longer if i remember right. Maybe somebody else will chime in with some info.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-27-2018, 03:13 PM   #5
MacQuigley
Unfortunately ive not got an original to compare with the new.
Old 11-27-2018, 05:22 PM   #6
Wrenchbender Ret
Those shafts don't look right. The ones Ive worked with were triangular shaped & had a pointed end with a groove near the end.
george
Wrenchbender Ret is offline   Reply With Quote
Old 11-27-2018, 05:26 PM   #7
MacQuigley
They are triangular with a point and a slot. Tried them again tonight and they will not lock in place no matter what I do. There is still plenty of length to go in so its not like they are too short.
I must be doing something wrong but I cant figure it out!
Old 11-27-2018, 08:04 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I struggle every time both ways.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-28-2018, 04:48 AM   #9
MacQuigley
Crazy think is the one on my 77 C3 just slipped in and locked in place. I just cant get this to do that.
Old 12-03-2018, 04:02 PM   #10
Rust-O-Matic
Rust-O-Matic's Avatar
Did the slider part inside the switch, which receives the shaft (giggity), get pushed down to the "off" position?
I accidentally pushed mine down when trying to reinsert the shaft/knob and couldn't get it to seat or stay put.
I ended up prying the switch housing open and moving the slider thing back up to the "on" position, put back together, held the lock button in, and the shaft dropped right in like it should have.
Rust-O-Matic is offline   Reply With Quote
Old 12-04-2018, 02:58 PM   #11
MacQuigley
That worked a treat. I must have pushed the switch inside each time I tried to install the actuator for the first time. I noticed with the last one the button seemed to go so far then stock but if you pressed a little more it went a bit further. I guess I wasnt pressing it hard enough.
Old 12-04-2018, 03:29 PM   #12
Rust-O-Matic
Awesome! Glad you got it back together. Those switches are frustrating.
Old 12-04-2018, 03:46 PM   #13
MacQuigley
The trick will be getting it right when i put it back in the truck!
