Old 11-29-2018, 09:51 AM   #1
Texasbigblock
Texasbigblock's Avatar
Hydraulic Clutch
Hi all,
I’m a 67-72 guy but need some square body help this time. I have a 1970 Chevy body, that I put on a 1985 dually chassis. I’m using the hydraulic clutch setup from the 1985 (trans, slave, bell housing, fork, etc...). I’m using the master from an 88 because the earlier models had an angled master that was more difficult to mount to the 1970 firewall. So the master is 1988, but everything else is 1985 stuff.
I have read tons of posts on how to bleed these and I’ve successful bled these before on different trucks. But, after many attempts, on the truck and on the bench, I still have no pedal. With the engine running I can’t get the truck into gear even with the pedal to the floor. I feel very little resistance from the pedal except right at the floor. When the clutch is held, I can go under the truck and it appears that the push rod on the slave is fully engage with the fork (I can’t move the fork AT ALL by hand any further.
Also, this shouldn’t effect my current issue, but is there supposed to be any kind of return spring on the clutch fork?
Any thoughts?
Still air somewhere?
I’m starting to miss my manual clutch.
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 11-29-2018, 10:04 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Hydraulic Clutch
Are you getting the clutch fork arm to travel far enough to release the clutch in your opinion...you could have a bad master or slave...or there's still air...that's why I like my mech clutches..all clutch arms I've seen have return springs but I havnt messed with a hyd clutch in a long time...
I doubt you could move the clutch arm by hand when engaged ..lots of back pressure from the pressure plate
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-29-2018, 11:57 AM   #3
v30crewcab
v30crewcab's Avatar
87 master is exactly the same as an 85, unless you got an s10 one. better post some pics so we can figure it out.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-29-2018, 02:12 PM   #4
Texasbigblock
I apologize. The master is for an 88. I’m using the 1970 clutch pedal, but I modified it some to hook up the newer model push rod. I set it up so the rod would push in about 1” into the master. I guess it could possibly not be pushing in far enough. Can anyone verify how much travel this push rod should have?
-Scott-
Old 11-29-2018, 02:14 PM   #5
Texasbigblock
I edited the original post to 1988 master.
-Scott-
Old 11-29-2018, 03:07 PM   #6
hatzie
Moderator
hatzie's Avatar
I had all kinds of trouble getting the air out of the slave cylinder on my 85 back in 1996.
It looked like the slave was angled such that the bleeder was not at the very top of the slave so air could still be trapped.
I unbolted the slave and oriented it with the bleeder at the very top and then opened the bleeder. More air burped out and the system worked after I re-installed the slave.
This was on a completely stock system so your hybrid might not be the same problem.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-30-2018, 12:04 AM   #7
v30crewcab
v30crewcab's Avatar
try taking the slave loose, and pushing the rod in and out slowly for awhile. thats the best way to get all the air out. if it doesn't work good then, might be mismatched sizes not working together.
71 longbed 5.3 4l80
