11-27-2018, 09:52 AM | #26 |
Active Member
Re: Torsion box cut out?
Does anyone have any advice on removing my old one w/o damaging the frame? Or are there threads (that I haven't found) showing that?
My left one was removed by the PO to install a poor fuel tank install and the right one is rusted through.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. Members Met: Aldtime, DeadheadNM |
11-27-2018, 03:14 PM | #27 |
It doesnt attach to the frame at all. It's only a body/tub brace.
11-27-2018, 04:23 PM | #28 |
- if all the body is still lined up - they are easy to install with a bit of welding along the bottom of the tub - they are bolted to the tub at the B-pillar.
11-27-2018, 08:41 PM | #29 |
Active Member
Got ya. I was just concerned about cutting those welds in the oval holes without damaging the tub/brace.
11-28-2018, 03:52 PM | #30 |
Sure, i get it you dont want to muck up the floor/other panels it's welded to - well just like cutting/grinding into any weld to separate two panels do your best not to get into the panel you DONT want to cut/remove.
Patience is your friend. Grind some, check the progress. repeat. Also having some sharp chisels or other tools to help pry on the torsion box/show you where the weld is still hanging on is helpful. |
11-28-2018, 06:34 PM | #31 |
Removing mine was a combination of 4" grinder with cutoff wheels, sawzall, hammer and chisel, bloody knuckles, and much cussing.
Have fun! Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
11-30-2018, 09:26 PM | #32 |
Active Member
I took this pic soon after I pulled the tank the PO put in. It hung down 3+ inches from the bottom of the truck.
Soon, I get to remove the flimsy fuel door. Anyone interested in an aux fuel tank setup?
12-02-2018, 12:21 AM | #33 |
Someone was looking for a fuel door over on the truck forum a week or two ago.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
