#376 |
Re: Columbus..the 1957 IH 4x4..
That looks great, and I'm sure will make some people scratch their heads.
My 57 GMC build |
#377 |
![]() ![]() Join Date: May 2015
Yep.....
#378 |
![]() Join Date: Jul 2012
That looks really good! Well done!
Are the folks suspicious yet? |
#379 |
Thanks Doug....as far as I know they don't have a clue...
#380 |
![]() Join Date: Mar 2008
That looks good Mongo. I was going to ask about the parents also.
NHRA Super Street 469C It only runs 10.90 at 156 mph I was Dragtruck when Dragtruck wasn't Cool! |
#381 |
Thanks Regan .....
#382 |
After 2 weeks of fighting a uti I finally felt like doing a little sumping....one thing on the list was tail light brackets...I wanted to use the originals but they just wernt worth saving....so I made a set from some 1/8" sheet...hammered the reinforcing dimple in the bend...looks close enough for guvment work...
#383 |
Nice work Greg. See your brackets and Reaper’s brackets reminds me I need tail lights for mine. Hmm...
#384 |
Thanks Doug... I'm thinking I'm gonna run my tail light wires thru some stainless tubing just to keep it clean...
#385 |
This truck is so cool! I'm really looking forward to seeing it all together and out in the sun.
My 57 GMC build |
#386 |
thanks old57.....your truck is sweet...
#387 |
Since I swapped in the. NV4500 in place of the old IH trans I had to do something with the e-brake/4x4/4low-hi levers....on the IH all this bolted to the side of the trans.....so I fabbed up a bracket to mount all this on...I welded it to the trans crossmember and added a brace off the frame...the nv is a wider trans as well so that moved all the levers over about 2in to the pass side.....so I had to make some modified linkage as well...got it all fabbed up and works great..will pull and pain't it all and thatll be another check mark on the list....
#388 |
![]() Join Date: Jul 2009
Nice work! Bet that was satisfying when it worked the way it was supposed to.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#389 |
thanks rgun...I kicked around several attempts at mounting the levers...wasted a lot of time over thinking it...finally just said screw it...thisll have to work...and it did..
#390 |
Problem solved, good work Greg! Pretty satisfying isn’t it...
#391 |
Thanks Doug....like they say on the A-team..."I love it when a plan comes together"!...even if it didn't start out that way..
#392 |
![]() Join Date: Apr 2008
Nice work on the linkage!
#393 |
thanks tigger!!!...
#394 |
SO when you pull it to paint it you will have to pull the whole x member? You have given me some great ideas for linkage with this configuration! Great job. I need to step my game or my tools or both!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#395 |
Thanks zepp... I've already painted the bracket I welded on the crossmember...i just taped it up and sprayed it...the parts i was referring to pulling and painting was the linkages
#396 |
Got the Eaton trac-loc in today...gonna go with all new gears as well...probably in 4.56s...
#397 |
Great job on the levers, that's nice! Jealous of the locker... I need to do that someday in mine.
My 57 GMC build |
#398 |
Thanks 57....
I was planning on doing the locker and gear swap all along but I was gonna wait till I got it drivable before doing it...I wanted to drive it on the 3.73s and g80 and see how it did...the other night I decided I would change fluid in the diffs....when I drained the rear about a half gallon of water and sludge ran out..(thanks P.O.).....I pulled the cover and wow what a mess....so the plans changed....and Eaton has a $50 rebate till 12/31..
#399 |
Another small side project was brake light and clutch safety switchs... I got a couple of normally closed plunger switches ,,,made some mounting brackets and welded some tabs on the pedal arms...works good ..
#400 |
Working on the steering column now...I wanted to keep the original steering column and had planned on using a Column Saver on it....when I got ready to buy ,I found they only make 2 sizes with the largest being a 2in...and those were on back order for 2 months...when I disassembled the column I found that of course IH made theirs 2-1/8"...so...I just made one....started with some 2-1/4" alum round stock ..cut the od to match the column dia and bored it for the bearing...fit very good so this should work just fine...
