Old 05-19-2004, 08:10 PM   #1
TIMSPEED
TIMSPEED's Avatar
Minimum amount of space between axle and frame??
On my 75 C10, how much space do I need between the axle tube, and the framerail, before I need to add a C-Notch? Would 2" Be too little space and I would run into bottoming-out problems?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-19-2004, 08:50 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you don't mind it beating the heck out of the frame 2" isn't bad..
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-19-2004, 09:05 PM   #3
Bowtie67
Bowtie67's Avatar
I went 3" on mine and the guys I purchased my 4link from said 3" as well. If you have a heavy setup of a suspension you should be able to get away with 2" but always keep in mind if you load it up to check how much room is here so not to damage anything.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-19-2004, 09:37 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
Don't be a wimp, install a notch.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 05-19-2004, 10:23 PM   #5
UltraDresser
so is the essence of the opinion of this mod is ... if you flip your rr axle.... "C" notch the frame?? I dedeuce correctly???
UltraDresser is offline   Reply With Quote
Old 05-19-2004, 11:13 PM   #6
swervin ervin
You get what you pay for
swervin ervin's Avatar
Yes, you deduce correctly. I used a shackle in the lower hole and a 5" flip kit, which gave me a 6" drop. I had 2-3/4" left in clearance between the frame and axle tube. I drove it this way for a few weeks. After one too many teeth rattling, bone jarring bumps, I installed a notch.
Tim,
install a notch in that thing and be done with it.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 05-20-2004, 01:23 AM   #7
TIMSPEED
TIMSPEED's Avatar
Well, right now, I have a FULL 5" of distance between the top of the axle, and the frame, so I think if I do the WC Shackles, and put them in the bottom hole and get the 1" of drop or so, I'll be ok. I probably will end up notching it though...
See Them Here
Old 05-20-2004, 08:28 AM   #8
crazy longhorn
Fabricate till you "puke"
I have 2 1/2" tween the axle & rails on my longhorn. it hasnt caused any problems, but those old leaf springs were pretty stiff. i do agree with the rest of the guys tho, you need a minimum of about 3" for a civilized ride. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-20-2004, 10:51 AM   #9
UltraDresser
is the 2" measurement with truck on load to ground? from bump stop to rail?
Old 05-20-2004, 02:16 PM   #10
Bowtie67
Bowtie67's Avatar
From frame rail to axle housing unloaded, I think that is the question your getting at. Thats not a whole lot of room especially with trailing arms and stock style springs, 200lbs will drop this pretty close to an inch and if you hit a pot hole or something it'll hit the frame.. BANG! You now have a dent housing and a little more clearance.
2009 Toyota Tundra
