05-19-2004, 10:04 PM | #1 |
Parts pics for Rod
Parts pcis for Rod
Saskatoon, Saskatchewan Canada |
05-19-2004, 10:08 PM | #2 |
more parts pics for Rod
Rod I tested the switch and it appears to be working. I has had the wires spliced.
I also tested the pod and it holds vacuum. The brake vacuum switch is damaged. The speedo cable looks good The extra newer model servo is included. All hoses and wiring are included
05-20-2004, 12:48 PM | #3 |
Other pics?
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
05-20-2004, 12:55 PM | #4 |
what is all this?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
05-20-2004, 01:31 PM | #5 |
To the Top
05-20-2004, 01:32 PM | #6 |
68 cruise control
05-20-2004, 02:10 PM | #7 |
how much is a cruise control worth?? i have it on my truck but i has given me nothing but troubles...
https://www.ebay.com/itm/29620574751...mis&media=COPY |
05-20-2004, 02:23 PM | #8 |
OK. I merged the 2 threads together.
Looks like the arm is wrong for sure but other than that I'll have to look at my pictures of units in my pics file to compare things... I'll have more time to do that tonight. Rod let me know what you have 70 402 and a pic always helps. email me if you like. Rod
05-20-2004, 02:36 PM | #9 |
I personally removed it from a 68 that had it on the glove box options list. The signal lever cruise switch wire is spliced so my guess is that it was replaced with another GM part at some time. I used to work for a Delco dealer as a kid and personally delivered about a zillion of those levers and the servo's to garages back in the early 80's
