12-24-2018, 02:06 PM | #26 | |
Re: Would you change rear gear?
Your kicker is the tires. Is your truck 2wd or 4wd? Those 31's are going to make your 3.07's feel like 2.73's. If you ever plan to run a smaller tire, the 3.07 gear would still work well, but if you plan to keep the same size tire, I would suggest a 3.42 gear to make better use of the rpm range of the engine. A LSD like an Eaton would also be beneficial to keep from one-wheel- peeling all the time. Also, FWIW, the 3.07 gear is a 3-series gear, and 3.42 is considered a 4-series gear, but you can get a gear made for a 3-series carrier.
12-24-2018, 02:41 PM | #27 |
It dynod at 333hp @ 5300. 388 tq @ 3700
12-24-2018, 02:49 PM | #28 |
Gear it.
My 2 cents: - You'll get more "go" from beginning to end. - Doesn't sound like you got this truck for family trips. - You've already invested in reasonably high performance modifications to your engine and transmission and with that cam your 3.07's are a bit low. - Chevy high performance vehicles of this era (67-72) ALL started with higher numerical gears. Small blocks 300hp and up, 3:73 std. , Big blocks 325 and up 3:42 or 3:55 std and our trucks are heavier are less aerodynamic. - 3:73 gears were a common option of our trucks and I believe std. with 6 cylinder trucks. - These trucks will never get great gas mileage no matter the gear. I have a similar set up to yours (well modified sbc, th400 with ati stall) and when I switched from 3:07 to 3:73 posi I experienced NO DIFFERENCE in gas mileage or highway drone although I was "tach'ing" more rpms. BIG DIFFERENCE on launch and anytime I hit the gas - especially on the highway. Around 3K i am on the early side of my torque curve and the engine is very happy. I think you will be too. Unless you have fuel injection and advanced timing controls, regularly operating your carburetor engine outside of your torque curve is not efficient. I did pick up 2 mpg in tuning...after the gears! - As far as drone, etc. if that's an issue - get better mufflers or run resonators in front of your existing mufflers, and/or insulate the cab. |
12-24-2018, 02:54 PM | #29 | |
