Old 05-20-2004, 06:22 PM   #1
rockguy
Front disc conv. 1 ton dually
Has anyone done this . I assume the parts for a dually 1 ton are different than single wheel due to the difference in the offset of the dually rim.
69 c-30 dually flat bed & dump ( best truck ive owned
87 chevy dually
97 1500 classic
89 wellcraft
rockguy is offline   Reply With Quote
Old 05-20-2004, 07:03 PM   #2
junkyardjohn
junkyardjohn's Avatar
I'VE PULLED A COMPLETE FRONT END OUT OF AN 82 1 TON TRUCK , & I'VE YET TO INSTALL IT IN MY 69 1 TON TOWTRUCK. I PLAN ON PUTTING IT UNDER IT SOMETIME THIS SUMMER. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-20-2004, 08:36 PM   #3
Rod
Lets us know how it goes there junkyardjohn, I got a 1979 one ton for parts if I need it... I spotted what looks to be a 68-69 in a field today....its got me interested too. But I prefer disc...actually I've never had a dually with drums yet but I sure like how my 72 stops with all the weight it pulls around. So Im interested in the swap also.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-20-2004, 10:39 PM   #4
pound41
I think the only thing you need are what some call the buds or the part that goes onto the rotor/drum to extend the rim away from the rotor so it sits back
pound41 is offline   Reply With Quote
Old 05-22-2004, 03:19 AM   #5
Duallie
Duallie's Avatar
3/4 ton disc spindles are identical and have the same part number as 1 ton disc spindles. Unsure about tierod ends. If you already have disc brakes on a 3/4 ton or a 1 ton srw, the ONE-PIECE duallie rotor/hub will bolt on and use your original caliper.
I do have a pair of duallie rotors that I don't need anymore. Shippimg from Alaska is usually prohibitive, however.
Duallie is offline   Reply With Quote
