Old 12-28-2018, 03:24 PM   #826
studeclunker
studeclunker's Avatar
Re: What did you do to your truck today part IV
Originally Posted by AcampoDave View Post
Found the rattle in my upper door above the weatherstrip channel. Damn mud dobber wasp nest. Problaby been in there for decades and just recently broke loose. Good thing it was abandoned...I would have freaked out if I was rolling down the road with a cab full of those s.o.b's flying around!
I have a '51 Spartanette (travel trailer) that was loaded with those. I filled a whole trash can just with 'Daubber nests (along with mouse poop, dead rodents and dead bugs). Dumped them out in the back pasture where they can return to the earth.
Your situation reminds me of the Caddie legends of bottles suspended in the rear fenders. If the rattle of that little 'Daubber nest bothers you, my truck would likely drive you right around the twist! It's a regular percussion symphony going down the road!
studeclunker is offline   Reply With Quote
Old 12-28-2018, 05:48 PM   #827
forestb
forestb's Avatar
I got my horns working off the steering wheel for the first time in 18 years. When I first got the truck it had a siren with a button under the dash. I installed a real horn and got a new steering wheel around 15 years ago. The wiring in the wheel that they sent me with the wheel did not work with the wheel. So I have been using the button under the dash until this weekend when I modified the wiring from another vehicle to fit the wheel.
forestb is offline   Reply With Quote
Old 12-29-2018, 10:41 PM   #828
Chevy Fleetside
Chevy Fleetside's Avatar
swapped out the alt in my truck and went to the speed shop to get some parts for my Mustang.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-30-2018, 05:17 PM   #829
Clyde65
Clyde65's Avatar
I put the rear bumper on the other day, I brought Clyde home from the shop the other day, replaced booster/master, panhard bar and some front end maintenance, He is getting closer! Only need to redo the grill and then the interior!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-31-2018, 08:06 PM   #830
rws1012
After sitting outside for 20 years I moved my 1966 Chevy fleetside into my garage. Will start rebuilding her. Original 3sp, 250 I6. Will get a new auto trans with power steering and disc brakes, thanks to CaptainFab and his awesome brackets. Good way to start New Year. Happy New Year to everyone!!!
rws1012 is offline   Reply With Quote
Old 01-01-2019, 02:53 PM   #831
straight6chevyguy
straight6chevyguy's Avatar
Are you keeping the 250?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 01-01-2019, 08:44 PM   #832
rws1012
Yes I am keeping the 250. Right now it is stuck. Haven't opened it up yet. I did buy an extra one a while back in case the original is toast. Worked o n getting the seat out today. Did not find anything under the seat such as money. LOL. Truck shows 87000 miles and I think it is right since I knew the second owner. I am the third owner.
Old 01-02-2019, 12:18 AM   #833
rws1012
Here is my truck as she set out for 20 years. Have a pic of it inside but it keeps posting upside down. LOL!! Will try to figure that out or will get another picture taken. 1966, 250 3sp on column
Old 01-03-2019, 04:39 PM   #834
straight6chevyguy
Great!
Nothing wrong with V8 swaps but I'm always happy to see someone keeping a 6 in there truck.
Way to many people junk them.
Old 01-13-2019, 06:17 PM   #835
PORKY
PORKY's Avatar
This weekend we got the rear wire harness in, installed the back up lights, tail lights, and rear bumper. Still lots to do!
PORKY is offline   Reply With Quote
Old 01-13-2019, 08:24 PM   #836
vin63
It's Better With Nitro
vin63's Avatar
Mounted and wired the headlamp relays. Fan relays next.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-13-2019, 09:52 PM   #837
Wildman61
[IMG]49044852_2297064050612238_799201089168605184[/IMG] 1961 long way to go. Edit. I guess I can't post pictures yet.
Wildman61 is offline   Reply With Quote
Old 01-13-2019, 10:50 PM   #838
Pinchecharlie
Started the floor and rockers. Fyi the after market stamped floor slid right in . Down side is cost . Upside is it took about an hour and half. Had about 10 hours in blasting though the enamel was very stubborn!!!
Pinchecharlie is offline   Reply With Quote
Old 01-14-2019, 08:46 AM   #839
nsb29
nsb29's Avatar
You can post you just did something wrong
nsb29 is offline   Reply With Quote
Old 01-14-2019, 11:39 AM   #840
1998c1500
1998c1500's Avatar
Worked on a toolbox/cooler for the bed of my truck.
Made it out of pallets and recycled materials. Still have to make the hinges, install latch(old door knob and latch with skeleton key) and cut the plexiglass and drain for the cooler side.
Here is a video of wood being "treated"
http://www.youtube.com/watch?v=Ga1xf...ature=youtu.be
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
1998c1500 is offline   Reply With Quote
Old 01-14-2019, 11:50 AM   #841
1998c1500
1998c1500's Avatar
Painted and installed the correct emblems and took the fake F*** ones off.
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
Old 01-14-2019, 12:00 PM   #842
1998c1500
1998c1500's Avatar
Removed sorry
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
Old 01-14-2019, 02:14 PM   #843
jbgroby
jbgroby's Avatar
Technically, "I" did not do anything, but R & B radio completed my upgrade and shipping it back, do I can finally install some sound. they upgraded it from just AM to AM/FM/iPod/Bluetooth ready. I'll put on the correct knobs when I get her in the truck.
jbgroby is offline   Reply With Quote
Old 01-14-2019, 11:23 PM   #844
Pontiacgurudan
I painted my dash and most of the interior, installed the new stereo. Hope to finish the painting this weekend and get started on the sound deadener.
Pontiacgurudan is offline   Reply With Quote
Old 01-14-2019, 11:25 PM   #845
vetnat
Wow, that interior looks great!
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 01-15-2019, 12:10 AM   #846
Pontiacgurudan
Thanks, it's amazing what a few cans of rustoleum can do!
Old 01-15-2019, 12:11 AM   #847
forestb
forestb's Avatar
Is the rest of the truck the same color as the top of the dash? Do you have any pics ?
Old 01-15-2019, 12:25 AM   #848
Pontiacgurudan
No the truck is black. I plan on making the interior like new and leaving the patina more or less in place. Fixing the rust and hitting it with satin black.
Old 01-15-2019, 12:29 AM   #849
Pontiacgurudan
I'll try this again.
Old 01-15-2019, 02:59 PM   #850
forestb
forestb's Avatar
Thanks for the pics. If I had a patina truck I would do the same thing. That dash color would make an interesting exterior.
