Old 12-28-2018, 04:44 PM   #1
shiftinggears
Correct Air Cleaner Assembly for 1969 K10 with 350 V8 with Quadrajet?
I have a 1969 K10 with a 350 V8 and Quadrajet carb. Carb has divorced choke. Truck has power brakes and power steering. No A/C. Truck has 4 speed manual trans if it matters.
I'm trying to find a correct air cleaner assembly. I have come across several different assemblies, but don't know which one is correct.
Does anybody have a picture of what would have been original on my truck?
Thanks in advance.
shiftinggears is offline   Reply With Quote
Old 12-29-2018, 01:02 PM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: Correct Air Cleaner Assembly for 1969 K10 with 350 V8 with Quadrajet?
This is the setup on my 1970 c20 burb, I think it is the same as a 69, c or k should be the same.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 12-29-2018, 01:17 PM   #3
factorystock
factorystock's Avatar
Same air cleaner, but a little cleaner. Should have a heat tube off manifold also. '69-'72 is the same.
factorystock is offline   Reply With Quote
Old 12-29-2018, 04:14 PM   #4
BLT gmc
Some early 69 didn’t have a dashpot. Otherwise identical to the pics above.
BLT gmc is offline   Reply With Quote
Old 12-29-2018, 05:23 PM   #5
shiftinggears
Thank you, everyone.
I picked up this air cleaner assembly today from a guy here in KC. It looks correct based on the photos you provided. It’s in good shape and should clean up nice.
Old 12-29-2018, 06:19 PM   #6
54blackhornet
54blackhornet's Avatar
Did you get the spacer that goes between the air cleaner and carb ? It has the connection for passenger side valve cover.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-29-2018, 06:35 PM   #7
CrewCab59
CrewCab59's Avatar
Here is a stock set up on a 72.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 12-29-2018, 07:54 PM   #8
shiftinggears
No - but I already had that piece and the hose. Based on one of the pictures - I believe what I have is correct. Thank you for asking.
Old 12-29-2018, 07:59 PM   #9
54blackhornet
Good luck with your K10
71 C-20
07 Magnum RT AWD
