#401 |
![]() Join Date: Jul 2012
Re: Columbus..the 1957 IH 4x4..
Nice work Greg!
#402 |
![]() ![]() Join Date: May 2015
Thanks Doug!!
#403 |
Well now! Do you have a "That was easy" button you are pushin? You are a metal magician!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#404 |
ha.... no easy buttons in my shop!!!!
#405 |
This unit just showed up on my doorstep....looks very nice...some slight shipping damage to the fins but I think they'll straighten out with a comb...
Youd think for what it cost itd come with a armed escort.... Made by Griffin....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-16-2019 at 02:33 PM. |
#406 |
Nice looking radiator and too bad about the fins...ouch.
Wondering about the lower outlet. Would having it on the other end of the tank help with hose fitment ? |
#407 |
Doug, I thought about relocating the inlet and outlet so I could use a over the counter hose...but I wanted to keep my factory shroud and it wouldn't fit if I moved the hoses....ive already ruffly test fit some hoses on the old radiator and I think itll be fine...top and bottom hoses will be 2pc hoses..im machining some aluminum hose connectors for them..and on the top hose im adding a shoulder to put a fitting in for the steam line...
the bottom hose will be simple...2 hoses with 90deg ends will work....the top one will be a little trickier but should work
#408 |
Gotcha, I should have known you would have a cool reason for that. Painting the radiator black?
#409 |
yes sir....black it is...waiting on the eastwood black radiator paint as we speak...
since a good bit of the fins will be visible from the front and I didn't want it standing out,,griffin says the eastwood paint is all they recommend
#410 |
Are you looking for a spring inside your lower hoses?
#411 |
Grumpy...I dont think I'll put one in at first...my other truck doesn't have one and I've never had a issue...but if it become a issue I'll definitely put a spring in....
#412 |
Cool,nice work on Columbus.
#413 |
Thanks grumpy!....
#414 |
Summit Claus showed up today with some more goodies...4.56 gears and install kits for front and rear and a phantom fuel pump from aeromotive
Also got the gas tank sealer from Bill Hirsch ....
#415 |
It's always a good day when parts show up... especially when they're all the right parts
My 57 GMC build |
#416 |
Yep...still waiting on the sending unit....
#417 |
Also I have about 4 different projects for the truck going on at the same time...got one finished this afternoon...on my radiator hoses I know I'm going go have to use a 2 piece hose setup...so I made these coupling pieces to do that...on the top coupling i added a fitting for the steam port hose to hook up to...I've got to get the correct size brass 90 for it... I just stuck a spare fitting i had in to check thread depth....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-23-2019 at 08:41 PM. |
#418 | |
It was great to meet you and work together at Doug’s Wire and Fire. I could have done without all that ice after the storm but the event was a blast!
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
#419 |
thanks Scott!...
good meeting you as well Scott....luckily I had 4wd so I didn't have any major issues on the way home...but I didn't get out of the icy roads til I got to tenn...made for a long return trip though
#420 |
And it was nice to meet both of you.
I was whining about the white out conditions driving 20 miles to dinner Saturday night. Those are nice pieces Greg. Looking forward to how it goes together. |
#421 |
thanks Doug....I plan on using the Gates Powergrip heat shrink hose clamps on these fittings...so no ugly hose clamps
#422 |
Got another little bit done...well almost done...I'm keeping the original gauge cluster ...
The original only has temp and fuel gauge and lights for gen and oil...I wanted all gauges..and they needed updated to modern type standards... So I gutted the old gauges out.... I had to do some surgery on the panel for the new gauge cleareance... pic is what a original looks like ..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-28-2019 at 12:43 AM. |
#423 |
I started with the gauge panel...the 2 center spots where the lights were had to be opened up to match the outer openings.....
Before and after
#424 | |
#425 |
Then I started with a set of autometer 1-1/2" short swing gauges...I had to remove the faces of the gauges to fit against the dash glass...I couldn't find a 1-1/2 fuel gauge so I had to use a 2" for it..
2nd pic shows layout...
