05-21-2004, 10:49 AM | #1 |
Pic or good diagram of fireing sequence on 350?
What is the fireing (sp?) sequence on a 350? Someone messed the spark plug wires up and i need to get them straightened out.. i have a chiltons manual, but its only for 73-79 trucks.. and doesnt have a good diagram anyways... help? i believe its electronic ignition... its a stock distributer...
Chris www.70chargerrt500.150m.com |
05-21-2004, 11:09 AM | #2 |
The firing order is the same for all small block Chevys. The cylinders on the driver side are odd, #1 is at the front. Passenger side are even, #2 is at the front.
If it is a factory intake manifold the firing order is probably cast on the intake surface in front of the carb. Find or establish the #1 position on the dizzy cap and move around the cap in a clockwise direction connecting wires from the dizzy to the cylinders in firing order. |
05-21-2004, 11:24 AM | #3 |
You get what you pay for
Here you go.
Mike 1985 Chevy C-10 |
05-21-2004, 12:03 PM | #4 | |
www.73-87chevytrucks.com
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
05-21-2004, 12:28 PM | #5 |
I thought about it after posting my reply. I knew someone would would get me on something.
05-21-2004, 11:42 PM | #6 |
Keep in mind that if the dizzy has been removed/replaced in the past, #1 may not be in that location. But that can be checked easily.
05-24-2004, 10:08 AM | #7 |
thanks a lot
