Old 05-22-2004, 06:16 PM   #1
dubie
dubie's Avatar
need some help QUICK
I am installing a new throttle cable. I ordered a new cable for a 4x4 seeing how my 350 is in the inline 6 position. It looks to be even longer than the cable I removed!!! Will this thing work ??
the new cable is on top and the old inline 6 throttle cable is on the bottom with the mounting bracket
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-22-2004, 06:29 PM   #2
Bowtie67
Bowtie67's Avatar
You may be able to get it to work like the one I first used when I put a cle inmine so I had to go out and find something much shorter because it was binding, but it might probally look a little awkward being all cramed to make it work. I thought I read a while back that the 4wd cable was longer than the regular cable something like 11 inches or 3in longer, don't remember.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-22-2004, 10:26 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
hey Dubie. what carb are you running? where do you plan on attaching at eng? on rear manifold bolt or back of carb. can you find a new one for the six?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-23-2004, 10:50 AM   #4
Slams_58
We have a q-jet mounted on top of a 350. We bought the 4x4 cable because all 4x4'x from these years came with the engine in the rear mounted location and thought a new 4x4 cable would work. But it just doesn't look like it's right for this application.
Slams_58 is offline   Reply With Quote
Old 05-23-2004, 11:53 AM   #5
Randy70C-10
Randy70C-10's Avatar
You get the engine running??
Randy70C-10 is offline   Reply With Quote
Old 05-23-2004, 12:00 PM   #6
Slams_58
HAHAHAHAHAHAHA!!! Right!
Old 05-23-2004, 12:12 PM   #7
Randy70C-10
Things will work out, trust me. You'll learn what not to do in the process, but it's a learning experience every time. You should see the crankshaft that I twisted.
Old 05-23-2004, 12:18 PM   #8
Slams_58
we're almost at the firing up stage. Just a few more things to hook up and then we can giver a try. Gonna take the day off of working on it and then get at it tomorrow, seeing how it's a holiday in Canada
Old 05-23-2004, 12:22 PM   #9
Randy70C-10
A holiday? Slackers, you made up a holiday just for general purpose didn't you?
Old 05-23-2004, 07:42 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Tim, I don't know if these help at all, but here are pics of my 2 near-stock 72 4x4's with the 350. One has an edelbrock carb, the other the OE qjet. Also included is a pic showing engine location in reference to firewall and RH frame.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-24-2004, 11:12 AM   #11
Slams_58
great!! thanks for those pics Jeff. Can anyone tell me how it re-attaches to the pedal?? It has a small white plastic cone that we can't seem to get to fit right on the pedal bracket
right here
