Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-06-2019, 10:19 PM   #1
CJM72
WTB: Front Sway Bar and Spring Plates for 4x4 Square
Looking for a front sway bar and the Dana 44 spring plates that it mounts to. Spring plates must be from a 73-78 K5 or K10 with a 2.75" OD axle tube. Need for a swap into a 1st gen K5. Shipping would be to 02767. Thanks
Name:  70 chevy 028.jpg
CJM72 is offline   Reply With Quote
Old 01-07-2019, 09:08 AM   #2
GonicGM
GonicGM's Avatar
Re: WTB: Front Sway Bar and Spring Plates for 4x4 Square
I believe I have both, will check. I'm not sure but I believe there may be different spring plates for early versus late on the dana 44. Earlier Dana 44's had a smaller axle tube, perhaps 2-3/4" versus the later 44 and 10 bolt with, I believe 3" tube. Can you confirm?
BTW, bought a Cadillac in spring from Mastria
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 01-07-2019, 09:24 AM   #3
CJM72
Small world! I live about 3 minutes from Mastria.
I believe the early dana 44 with 2.75" axle tubes was from 67-78. I'll measure my axle tubes and the bolt hole centerline on the spring plates themselves tonight. I guess the earlier the better.
Old 01-08-2019, 07:16 AM   #4
GonicGM
GonicGM's Avatar
Put my eyes on a sway bar and a drivers side spring top plate yesterday.
Old 01-08-2019, 09:59 AM   #5
CJM72
My axle tubes are definitely 2.75" OD. The center to center dimension on the u-bolt appears to be around 3.44". It's hard get a good measurement on this when the plate isn't loose. If the u-bolt is 5/8" diameter this would make sense. I'm guessing that a spring plate for 3" axle is closer to 3.625" center to center. Let me know what you have.
Thanks, Chris
Old 01-10-2019, 10:44 PM   #6
CJM72
Any chance you found a passenger side plate? Do they match up with the dimensions I posted?
Old 01-11-2019, 10:33 AM   #7
GonicGM
GonicGM's Avatar
I measure mine at 3-11/16".
Old 01-11-2019, 05:37 PM   #8
CJM72
Looks like your plates are for a 3" axle. Thanks for looking into that for me.
I'll revise my search to plates from a 73-78 K5 or K10!
Old 01-12-2019, 11:30 AM   #9
KrazyRay
KrazyRay's Avatar
I have sold a hundred of these and the square body spring plates work fine with the 2.75" axle tubes. If you are worried about fitment, it is not tough to slot each hole 1/8" to make up the difference. My 2 cents worth.
KrazyRay is offline   Reply With Quote
