700r4 cooling line diagram
Can someone please tell me the correct way to run the cooling lines from my 700R4 to the radiator which have the side Inlet and Outlet ports and then to an external transmission cooler in front of that and back the transmission please thank you
![]() ![]() Join Date: Oct 2014
Re: 700r4 cooling line diagram
Here you go...https://679artists.com/350-turbo-tra...grams/#content
![]() Join Date: Feb 2016
Interesting, the transmission cooler connections on your radiator come out the side of the tank. I've never seen one like that. Can you post us a photo?
Here is a link that may help you. http://67-72chevytrucks.com/vboard/s...d.php?t=513643
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Moderator
![]() Join Date: Jun 2017
I usually totally bypass the radiator system and plumb directly into the aux cooler....
Why heat the oil up in the radiator to then try and cool it in the aux cooler? Block to fitting ports in the radiator... Just my opinion... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
UHHHMMM
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
I work at a transmission shop and we bypass the radiator and go straight out to the auxiliary cooler. The transmission coolers we use have a bypass that allows the fluid to reach operating temperature by running through only two channels in the cooler. Once it's warmed up the entire cooler is used.
Old member
Doesn't matter how you run the lines as long as it stay's below 200* according to GM. If it starts getting over 200* it starts breaking down the fluid and in turn starts breaking down the transmission. Doesn't matter which line is return because it's just a loop. The trans pump's the fluid out one and in the other so it don't matter.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#8 | |
Oh and welcome aboard Jramirez67c10 Here is a recent discussion about where to place the cooler in the loop. http://67-72chevytrucks.com/vboard/s...d.php?t=779001
The cooler is a Hayden By-Pass Transmission Cooler. Not sure what temperatures it opens at. On most newer trucks we can access transmission data with a scanner. There's usually a transmission temperature line and most of them sit around 190°. We've had customers who tow with diesel truck say that the temp gauge never exceed 215° when pulling a heavy load up a large grade. I hope the info helps.
#10 | |
At the body shop.
Advance Adapters Flexible Transmission Cooler Lines 23-1501
These and this cooler Derale Electra-Cool Remote Fluid Coolers 13720 Fan comes on with the high speed fan bypass the radiator altogether.
" That didnt make it any newer " " Dont antique the equipment " |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's how I routed mine but I didn't count on the dirt dobbers plugging the output line from the trans. I haven't tested it yet to see if the cooked fluid hurt the trans. I agree with Andy on the routing.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Install one of these just in front of your AUX cooler. This will prevent the fluid from being cooled until it reaches 180 degrees ( good for all weather environments, but especially for cold ones )... https://www.summitracing.com/tx/part...5792/overview/
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Some say it's also a good idea to install an aux filter after the radiator and before the aux cooler... https://www.summitracing.com/tx/part...oling-products
#15 |
Old member
If I lived further north I would add this to mine.
I drove my truck this morning and was watching my temp on the transmission. It stayed at 175* the whole time it was 33* outside. I like it like that. The motor temp was 200* ![]()
#16 |
Msgt USAF Ret
If you lived further north you would park it in the winter like the rest of us. ![]() I like the Made in USA stamp on the product. VV
#17 | |
Old member
![]() Quote:
That sir is a correct statement! ![]()
#18 |
#19 |
![]() Join Date: Mar 2018
Would you put the temp sensor in the output line leaving the trans? And also if you use a large cooler why wouldn't you bypass the radiator so that the trans wouldn't add heat to the engine? Especially if using the thermostat like above.
#20 | |
Old member
![]() Quote:
My thinking is as long as I know the total degree of the fluid after it's been through the transmission and it's less than 200* as GM likes it to be I'm good. If the temp starts climbing I know something is wrong. As far as the aux cooler goes yes if you can get one big enough to handle it on it's own then go for it. I had limited space for mine so it is what it is and as far adding heat if everything is working then it shouldn't add muh of any heat. ![]()
#21 |
![]() Join Date: Dec 1999
On the 700 trans I purchased from Bow Tie Overdrive years ago they had it set up so the sensor is in the pan. Generally reads around 180*. As stated before running a Hayden cooler with an RV application. Plumbed to the radiator and then aux cooler on the way back to the trans.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#22 |
I have an aluminum deep finned pan and was worried that it might give a false low reading but it would be the easiest place to put one.
