Old 01-10-2019, 09:07 AM   #1776
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: How to: Ruin a perfectly good C10
I like this direction, I'd paint the intake orange and the air cleaner lid black too.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-10-2019, 02:24 PM   #1777
SCOTI
SCOTI's Avatar
Originally Posted by gringoloco View Post
I really like the air cleaner setup. Is that the LT1/Z28 base?
Yes. The only mod was the breather tube @ the bottom of the base. It required tweaking for my app (to clear the TB).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-15-2019, 03:50 PM   #1778
mcbassin
Still Learning
mcbassin's Avatar
Either way Chris, These setups are way sexier than 99% of the LS motors out there in our trucks. Including my own. I dig it either way.
Old 01-15-2019, 04:20 PM   #1779
SCOTI
SCOTI's Avatar
I have absolutely no problem w/a 'de-cluttered' OE-LS look or a cleaned-up & engineered appearance on the LS platform. That being said, the truck style engine cover is the only one I care for as others appear 'gimmicky' when used in swaps.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-15-2019, 05:08 PM   #1780
Orange67
Orange67's Avatar
I agree with your Muncie/Hurst/grey spoke idea for the hi-po look. Tough decision, because they both look awesome. You could do like some guys do with wheels, keep both around and switch them out when you get bored with the current look. Keep it up man, you are doing great.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 01-15-2019, 05:25 PM   #1781
slowcpe
slowcpe's Avatar
I'm starting to really like this look. I've been considering something like your first pic on my '67 but more of a cast/brushed finish for the breather and valve covers.
I also saw on IG where someone painted the engine with script valve covers a fawn color which would match my interior. I thought that might look cool.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-29-2019, 01:09 AM   #1782
Daryl87
Daryl87's Avatar
I've finally made it all the way through this thread so far!
After a long hiatus, I'm just at the point of body re-assembly (inside of cab painted and firewall) and cab ready to be installed on the frame. Unfortunately my rolling chassis was pretty much completed before I got pulled into this build thread otherwise it probably would have influenced a bunch of the choices I made then (3-ish years ago). I'm also going 6.0 LS but with a 6-speed, so am interested in your setup and detailing of the engine.
Thanks gringoloco for all the effort you put into showing and explaining all the great work you are doing on your builds!
Daryl87 is offline   Reply With Quote
Old 01-29-2019, 09:25 AM   #1783
TA_C10
TA_C10's Avatar
More progress with the dash final sanded, in color, and cleared. Color match is pretty good and the clear laid out nicely. I got some trash in the ashtray lid that I hope to wet sand out, but overall I’m pretty happy with how this turned out
Super nice build thread Chris. I have been keeping up with your thread for about 6 months now after reading the bulk of it and not being able to stop
When your doing small work like the radio portion of the dash, are you using an aerosol primer or are you using a gun? And what brand of primer are you using? Do you use epoxy and 2k high build or something else? Just looking for similarities to what I'm about to do on my build.
Thanks,
Tom
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 02-16-2019, 08:58 PM   #1784
gringoloco
A guy with a truck
gringoloco's Avatar
Appreciate it, very much. I just hope that my rambling can be helpful or entertaining.
Thanks,
Tom
Thanks for the kind words. For the dash, I used aerosol products from SprayMax. Super high quality, professional, 2-part paints in the convenience of a spray can, highly recommend. I also had my local paint store mix up the base coat in a rattle can, so that whole project was “spray paint”.
I did break out the real paint gun today, though (more to come).
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-16-2019, 09:09 PM   #1785
gringoloco
A guy with a truck
gringoloco's Avatar
So, a brief update on the valve covers: I’ve decided to stick with the orange and black theme under the hood. As much as I like the “chrome” look, I’m just not in love with it.
Since I don’t want plain valvecovers, but I also don’t want the leaks that come along with stamped steel stockers, I decided to modify the billet specialties pieces to look more like GM parts.
I used the aluminum brazing rods you see at all the car shows to attach 2” x 1/8” strips to the tops. They still need a bit of body work, but I’m liking the concept. They will get painted orange to match...
-Chris
Old 02-16-2019, 09:17 PM   #1786
SCOTI
SCOTI's Avatar
Interesting. I like this direction.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-16-2019, 09:20 PM   #1787
gringoloco
A guy with a truck
gringoloco's Avatar
I also placed an order with Rick’s Upholstery in TN. I came up with a door panel design that pays homage to the ‘72 style, but without the bulky plastic feel. While they are building the door panels, they will also be providing a new seat cover to match. I hope to see these items in the next month or so. Finally doing away with the “temporary” horse blankets that have been there for, what 7-8 years now
-Chris
Old 02-16-2019, 09:21 PM   #1788
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, Scot. It came to me in a dream
-Chris
Old 02-16-2019, 09:26 PM   #1789
gringoloco
A guy with a truck
gringoloco's Avatar
...and in other news:
Firewall is painted! Layed some HotRodFlatz LeMans blue today and it came out looking pretty good. Not perfect, but as I age, I’m learning to live with that
-Chris
Old 02-16-2019, 09:28 PM   #1790
gringoloco
A guy with a truck
gringoloco's Avatar
And with the masking removed, still not fully dried, but I couldn’t wait
-Chris
Old 02-16-2019, 09:31 PM   #1791
rustytruck50
rustytruck50's Avatar
Looks great Chris...may need to borrow/steal the seat cover design...if not a couple more things....like the old saying goes "imitation is the sincerest form of flattery"
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 02-16-2019, 10:45 PM   #1792
smbrouss70
smbrouss70's Avatar
Everything looks fantastic! It's showing all the effort that you put into it. Unfortunately, now I'm going to have to modify my valve covers.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-17-2019, 12:00 AM   #1793
gringoloco
A guy with a truck
gringoloco's Avatar
I have no copyrights, yet
We seem to keep doing this to each other. If it helps you feel any better, every time I see your Blazer I think I need new wheels...
-Chris
Old 02-17-2019, 12:05 AM   #1794
3757chevy
3757chevy's Avatar
I like the door panel plan , can't wait to see it done. Seat looks good . Oh ya, the firewall looks great.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 02-18-2019, 12:07 AM   #1795
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks a lot. Really looking forward to getting the upholstery installed
Feels good to be finally bolting some things on again. The truck now has 3 pedals! The CapatainFab hydraulic clutch master works nicely, but took a bit more trimming than I had planned for. Still managed not to destroy the freshly painted firewall, so that’s a bonus...
-Chris
Old 02-18-2019, 01:20 AM   #1796
cornerstone
cornerstone's Avatar
These creative subtle modifications are why this truck will truly be one of a kind. I can't help but pat myself on my back thinking that I had some influence on your no chrome decision I'm seriously loving your orange and black choice! Chris, you mentioned Rick's Upholstery will be providing a seat cover to match your door panel design. The blue seat cover you posted appears stock to me, is that the one from Rick's?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-18-2019, 11:08 AM   #1797
gringoloco
A guy with a truck
gringoloco's Avatar
Appreciate the compliments and the influence
The example seat cover pictured above from Rick’s mimics the factory “waterfall” style, yes, but will be patterned to fit my 88-98 bench seat. There will also be French seams around the edges, instead of piping. Just a few subtle changes to modernize the classic, original look. I think I may have just unintentionally established a theme...
-Chris
Old 02-18-2019, 11:13 AM   #1798
gringoloco
A guy with a truck
gringoloco's Avatar
duplicate...
-Chris
Old 02-18-2019, 03:13 PM   #1799
timmytimm3
Love it!
Save the manuals
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 02-18-2019, 03:42 PM   #1800
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by timmytimm3 View Post
Love it!
Save the manuals
Thanks, and I agree 100%. I just read a Car and Driver article about the new GT500, and the moment I read “manual transmission not available”, I flipped the page to the next article. Not that I would buy one, but I don’t even wanna read about a paddle shifter
-Chris
