Old 01-14-2019, 01:33 PM   #1
bigmac73
bigmac73's Avatar
rear sway bar info
Gents,
Any benefits to this with stock ride heights? or will this even work?
63-72 Rear Sway Bar 7/8" Coil Spring Trucks
1963-72 Rear 7/8" sway bar for 2 wheel drive coil spring equipped trucks. Includes all necessary mounting hardware. Some modifications are required to install if vehicle is stock height.
https://gmcpauls.com/pictures/63-72rearcoilswaybar.jpg
Curious about what modifications needs to work??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-14-2019, 05:20 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: rear sway bar info
Nothing more than drilling holes after you square the unit on your trailing arms. I think CPP and POL all make/sell them as well.
Old 01-14-2019, 08:18 PM   #3
applebmw
Originally Posted by bigmac73 View Post
Gents,
Where can this be bought??
applebmw is offline   Reply With Quote
Old 01-15-2019, 10:21 AM   #4
bigmac73
bigmac73's Avatar
dose some one have a pic of it installed? I am curious where i have to drill holes??
I installed the solid rectangular tube trailing arms, not to keen on drilling into them
Mike
Old 01-15-2019, 12:00 PM   #5
The Rocknrod
Moderator
Installed:
http://67-72chevytrucks.com/vboard/s...7&postcount=36
POL web site - https://www.performanceonline.com/19...r-Coil-Spring/
Old 01-17-2019, 12:22 PM   #6
bigmac73
bigmac73's Avatar
Thanks Master Chief ,
One more question did it come with dimensions or instructions on where to place and drill?
Mike
Old 01-17-2019, 02:23 PM   #7
The Rocknrod
Moderator
Yes it did.
