Old 04-04-2002, 09:11 AM   #1
dubie
dubie's Avatar
Post Swapping a 3spd to a 4 spd??
If I swap out my original 3 spd when I convert from an inline to a 350, what all has to be done? Do i need to move the cross member? do I need a different driveshaft? any clutch components needed? i'm just gathering info right now, so when i get this 350 rebuilt, i know where to go from there. Thanks again guys.
72 C/10 LWB 2wd
250 inline 6, 3 speed column shift. Soon to have a total facelift.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-04-2002, 10:11 AM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Post
Well if you are talking about swapping to a SM465 (granny low) You will have to change your driveline and the hump in your cab. Everything else should be the same. WES www.ClassicHeartbeat.com
Click (Here) to visit our on-line catolog.
E-mail me WEHEPP@attbi.com
72 BB Chevy Blazer
72 BB Chevy Short Fleet
72 SB 3/4 Ton 4X4
72 SB 1/2 Ton SWB 4X4
70 BB Chevy Short Step
70 SB Chevy Short Fleet
69 SB Chevy Short Step
68 SB Chevy Short Step
68 BB GMC Long Fleet
67 GMC 1/2 ton Panel
"Founder" Classic Heartbeat Pickup Club
Olympia, Washington's "Home For Wayword Chevys"
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-04-2002, 10:22 AM   #3
69 longhorn
Post
If you move to V8 position,I think you need to also change the crossmember under the bell.......not 100% positive,but to move the bell crossmember foward,it will also raise it up......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-04-2002, 11:27 AM   #4
okietruck
Post
I'm considering the same swap but with a New Process 4 speed overdrive. I have the 3.73 rear end in my '72 LWB and the overdrive would help on the highway. I've already done the I6 to V8 swap using V8 engine mounts. Would the same changes, hump & driveline, apply?
'72 LWB Stepside
okietruck is offline   Reply With Quote
Old 04-04-2002, 10:51 PM   #5
Fast68Chevy
Fast68Chevy's Avatar
Post
alot easier to swap to th350 from a 3 speed because of driveshaft length issues, but with the sm318(if you have that one which is what came in 67 68 250 trucks) then it wil be a yoke problem too- just like with the ch465,
no reason to move crossmember though- the bellhousing is what bolts to the x-member, no need ot move any of it unless youre replacing or moving engine,
oh and its a major pain in the ^$#%@*! to bolt the bellhousing to the crossmemeber mounts(those two bolts) when engine is bolted to the housing.
Dont be surprised if you throw some tools across garage or yard a few times in a fit, having a junk car or two and a splitting maul is a great thing toi have in those times
Randy- Lincoln, IL
r68c30@hotmail.com
71 C-10, trying to assemble....sigh..
parting out 5.0LTPI '81 cutlass supreme brougham
*Paint is overrated
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited April 04, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 04-05-2002, 05:29 AM   #6
Firearmfiend
Post
doesn't the tranny sit farther back on an L-6? I've noticed that the shifter for a 4-speed on a V-8 comes through the hump farther forward (at the bend up toward the firewall) as opposed to the L-6 (on the flat part of the hump.
also, start looking for a bolt-in high tranny tunnel hump now... I lucked out and found one out of a V-8 2wd truck (only one hole in the hump and it's in the right place)... I even got the crome beauty ring/shifter boot ring with it and all the bolts and screws!
'70 C-10 Short/Fleet 350 (in the family since new)
'70 C-10 Long/Fleet 307 (the Death Machine because it seems like it'll kill you to drive in it)
[This message has been edited by Firearmfiend (edited April 05, 2002).]
'70 C-10 Short/Fleet 350 In the family since new and more than 300K on the odometer!
Firearmfiend is offline   Reply With Quote
