Old 01-25-2019, 09:58 PM   #51
garyd1961
Re: wierd cooling system problem noise ?
Whatever works, I'm glad you got right. Your way should be really good for an AC truck with the cut-off valve in the line. Here is a picture of mine before I installed a new heater core and plumbed it in. It's still the same except now the water runs through the heater core and back to the pump.
garyd1961 is offline   Reply With Quote
Old 01-25-2019, 10:10 PM   #52
SunSoaked
SunSoaked's Avatar
I got the same setup as k30. Vortec heads and serpentine drive. I never had any problems. This thread made me think so I did some investigating. The ONLY time I don't have flow thru the block/pump is when the thermostat is CLOSED AND the A/C is ON! That's because I have Vintage Air and it uses a heater block off valve that closes of the heater core when the AC is on. For that one rare occasion, I went ahead and installed a bypass hose (see pic). Kept it simple-less than $5 in parts. Problem solved.
SunSoaked is offline   Reply With Quote
Old 01-25-2019, 11:36 PM   #53
sweetk30
sweetk30's Avatar
sun soaked . . . same rpm intake and arp bolts no less and temp sender in the bypass port .
i guess i am the unlucky guy the first 2 didnt work good and it needed the bypass port direct to the intake .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-25-2019, 11:50 PM   #54
SunSoaked
SunSoaked's Avatar
I'll say it again... those hubcaps are bad luck. Take them off and send to me.
Old 01-31-2019, 07:53 AM   #55
The Rocknrod
Moderator
The Rocknrod's Avatar
Check out this bypass pic from a 65 with a V8 board member cru_zn_29 owns:
Old 01-31-2019, 12:26 PM   #56
sweetk30
sweetk30's Avatar
nice pic .
i got my 90* and 45* barb fittings the other day . when my new intake shows up and gets installed i will post a few pics of the cleaner install and new intake setup i picked to feed the truck .
Old 01-31-2019, 01:30 PM   #57
The Rocknrod
Moderator
That engine is a 1965 model 327 (or 283?), using a bypass? Old style heads? Hello?
Old 02-01-2019, 12:00 AM   #58
Captainfab
60-66 Nut
That factory bypass was used on mostly medium duty trucks back in the day but some light duty trucks came with them also.
Old 02-01-2019, 06:57 AM   #59
The Rocknrod
Moderator
Good info. That's something I never realized, so it's not new for small blocks. Interesting.
I looked at 5 different 60's small block cast steel intakes on eBay they all have the bypass nipple attached. I never noticed that before.
Old 02-02-2019, 12:07 AM   #60
Captainfab
60-66 Nut
The factory small block thermostat bypass you posted a pic of, actually uses a piece that installs under the thermostat housing which the bypass hoses attaches to, What you were seeing on those 5 cast iron intakes is likely the heater hose nipple.
Old 02-02-2019, 05:23 AM   #61
The Rocknrod
Moderator
Good info there, thank you,
Old 02-03-2019, 12:43 AM   #62
Captainfab
60-66 Nut
Post #3 in this thread shows what I am talking about.
http://www.67-72chevytrucks.com/vboa...d.php?t=780199
Old 06-12-2024, 10:39 PM   #63
AustinBelair
I am losing my MIND trying to read and learn all of this. So far Google has me deep down a rabbit hole haha. So, I think I can run a regular reverse flow long pump (Like from a TPI 3rd Gen camaro) and just run a nipple in the top of the water pump to the 3/8 NPT water bypass in the front of the Edelbrock Vortec intake that I have?
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 06-12-2024, 11:00 PM   #64
SunSoaked
SunSoaked's Avatar
That's it.
