Old 01-26-2019, 09:21 PM   #1
WOLFMANmike
WOLFMANmike's Avatar
Door over close problem
so i took of my weather stripping and was gonna put on new new kit. but i discovered that the idiot who owned the truck before me replaced the rockers with ones that don't have the pinch weld along the rocker for my weather stripping. So now comes the bigger problem, I was upset and quit for the day to figure what what to do so I shut the doors and locked up come back out days later, driver door opens just fine passenger door? nope! will not budge i called my good friend mike he told me oh yeah he had it happen to him before the door is over closed now. With no weather stripping in it he said he had to pry his open with a pry bar! if this is the only way then so be it but I am just asking is their any other way to get it open again? without prying on it ? I really don't want pry it and most likely bend the metal of the door or the rocker or both ? I am asking is their another way to do this where i wont damage my truck? Thanks guys my buddy mike knows a bunch about these trucks so i trust him that is not a issue i just really want to get it open without hurting it ya know
WOLFMANmike is offline   Reply With Quote
Old 01-26-2019, 09:34 PM   #2
Llay R. Rac
Llay R. Rac's Avatar
Re: Door over close problem
you might try some plastic pry tools, i bought a cheap 10 piece set to take off trim on my toyota , i have put them to good use on my suburban. really helped put weatherstrip on my side windows and a few other general prying against metal jobs.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 01-26-2019, 09:36 PM   #3
WOLFMANmike
Problem is I don't think that plastic ones will be strong enough to pry open the door I have pulled with all my force and all my weight I weigh 400 lb to try and open this door and it won't open it won't budge so Something tells me that the door would just laugh at a piece of plastic trying to pry it open
Old 01-26-2019, 09:44 PM   #4
Llay R. Rac
i heard a good boot from the inside will open a stuck door. good luck.
Old 01-26-2019, 09:45 PM   #5
WOLFMANmike
tried that too
Old 01-26-2019, 10:14 PM   #6
ls60apache
well it involves a little work...one option is to remove the cowl extention...loosen the fender at the bottom to access the hinges to wiggle the front of door to try to separate the latch....or maybe access latch by removing door panel...Good luck
ls60apache is offline   Reply With Quote
Old 01-27-2019, 10:35 AM   #7
vin63
It's Better With Nitro
vin63's Avatar
Before you start using pry bars and damaging the sheetmetal, try removing the front fender and cowl corner to access the hinges. Loosen the bolts that hold the hinge plate to the cab and door. Hopefully, by allowing the hinge mounts to move will take enough tension off of the door to allow it to open.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-27-2019, 01:37 PM   #8
nsb29
nsb29's Avatar
I started a post but erased it got to thinking do you have the latch installed or do you think it’s stuck on the rocker
nsb29 is offline   Reply With Quote
Old 01-27-2019, 01:47 PM   #9
WOLFMANmike
Everything is installed it's like this the doors were working just fine for years but I took off the old weather stripping to put on new stuff and could not put the new stuff on yet so I shut the door and ever since then I can not open it so yeah think of a full complete door minus the weather stripping
Old 01-27-2019, 02:00 PM   #10
nsb29
nsb29's Avatar
You probably should do like vin63 said mine got stuck when I was fitting them but wasn’t panted and was abel to open it with a flatbar
Old 01-27-2019, 06:28 PM   #11
Railroader
Railroader's Avatar
My suggestion would be to get your fried press the door button from the outside, apply pulling pressure on the handle while you hit the inside of the door with rubber handle. For more force you could use a piece of wood against door and use a 3 or 4 lb hammer. Hold wood tight against door at latch location.
Good Luck
Railroader is offline   Reply With Quote
Old 01-27-2019, 06:29 PM   #12
Railroader
Railroader's Avatar
Can't spell. Friend not fried.
Old 01-27-2019, 06:42 PM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
Reminds me of Galaxy Quest.
Old 01-28-2019, 07:56 PM   #14
jdl71
jdl71's Avatar
Lay down in seat and push with feet while someone else operates button on outside and pulls.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 01-28-2019, 08:12 PM   #15
WOLFMANmike
hey guys thank you all of you for all your suggestions and valuable help!
I am happy to say that i got open before having to dismantle the cowl corner and the front fender. it is funny how bad it was jammed shut that nothing done not having a guy lay down put pressure with his feet and me hanging my full 400lbs on the handle just shook the truck all over lol nothing would make that SOB give. LOL in the end the guy inside rolled down my window and said hand my the pri bar he stuck it between the door and the door jam right where the latch would be and literately applied the amount of pressure it takes to crack your knuckle and it popped right open LOL with just me pushing the button no yanking no extra damage done and door it open soon i will be putting on my new weather stripping on and wont ever be a issue again lol but much thanks to all of you
Old 01-28-2019, 08:17 PM   #16
WOLFMANmike
call me superstitious but after posting this i saw the log under my name of how many posts and it was 666 no thanks ! so that is the reason for this post now
Old 01-28-2019, 11:30 PM   #17
vetnat
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 01-28-2019, 11:39 PM   #18
kazoocruiser
I dunno, but I think if you had rolled down the window, and applied upward pressure at the rear corner window opening, it would have lifted the door off the part it was binding against. The weatherstripping will force the door up a bit and mask a misalignment
kazoocruiser is offline   Reply With Quote
Old 01-29-2019, 08:48 AM   #19
nsb29
nsb29's Avatar
LMAO. Yeah that’s what I did when mine got stuck But I didn’t have to worry about Paint it still look like the aviator
Old 02-01-2019, 01:02 AM   #20
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
thanks for this ,I will try it next time It happens to me , last time I dented the door on the inside from kicking it.
Old 02-01-2019, 01:06 AM   #21
WOLFMANmike
Yes sir no problem but I will say also the door was badly out of adjustment so a good re adjustment will also do wonders as well
Old 02-01-2019, 09:00 AM   #22
nsb29
nsb29's Avatar
The little rubber bumpers would also keep this from happening
Old 02-01-2019, 01:33 PM   #23
WOLFMANmike
Would this be a add-on or is there some from the factory that I'm missing I don't know about?
Old 02-01-2019, 05:59 PM   #24
nsb29
nsb29's Avatar
No not add on original my 65Name:  E991973E-8F53-40D7-A284-70240D201043.jpg
Old 02-01-2019, 06:03 PM   #25
nsb29
nsb29's Avatar
Printed Name:  3F2CA306-DB93-4752-8299-738A274AFB76.jpg
Size:  29.3 KBthe same picture twice
