01-27-2019, 12:50 PM | #1 |
MOTORHEAD!
Dash pad/gauge bezel interchangeable??
Can a dash pad and gauge bezel from a 73-80 be installed in an 81-87 truck? I’m trying to build a 73 out of an 82 cab.
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
01-27-2019, 03:56 PM | #2 |
Re: Dash pad/gauge bezel interchangeable??
I am pretty sure it will work I do know they are shaped just a little bit different but will work . also the wiper switch is on the 73-80 bezel and 81 up has it on the turn signal lever .
4x4k30 if trouble was money i would have plenty |
01-27-2019, 04:15 PM | #3 |
MOTORHEAD!
Depending on options.... my 82’s both have the wipers on the bezel/no cruise control
01-27-2019, 10:19 PM | #4 |
I believe the wipers were moved to the column in 84.
My 83 still has them on the dash too.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
01-28-2019, 05:48 PM | #5 |
MOTORHEAD!
Anybody have any experience with putting a 73-80 dash in an 81-87? Does the 73-80 dash and gauge bezel require the 73-80 cab? Or are the cabs identical?
Thank you!
01-28-2019, 05:54 PM | #6 |
Cabs are identical.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-28-2019, 06:12 PM | #7 |
MOTORHEAD!
My thoughts exactly. I will carry on with my conversion!!!
01-28-2019, 06:29 PM | #8 |
There were some changes, over the years, of the dash pads & bezels. There was an old thread that discussed all the changes. I was trying to locate it, but so far, no luck.
01-30-2019, 09:33 PM | #9 |
73-80 will fit 81-87 etc. However, the VIN will either be partially covered by the 79-80 VIN opening, or fully covered by the 73-78 dash pad. Also, at least when I test fit my 79 dash pad on my 85 cab, the VIN on the 85 cab was raised a bit and caused a bump in the 79 pad. See post #94 on my 79 GMC build below. I test fit the 79 dash and 79 cluster bezel on the 85 cab.
Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
01-30-2019, 11:51 PM | #10 |
I tried to put my 88 suburban dash into my 79 c30. Not sure if it was the model or year difference, but it just didnt really fit right. I didnt try to massage anything
02-01-2019, 10:42 PM | #11 |
MOTORHEAD!
Thank you guys for your input!
02-01-2019, 11:03 PM | #12 |
The older pad fits the '81 and up dash, but the clip tabs in the upper corners just go into the speaker openings. You also need to use the 70's bezel, but that poses a problem in the '84-up trucks. You "can" use the newer bezel, but it fits terribly.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
